PCB assembly
I have prototyped a new propeller design
I am trying to find a US PCB assembler who can do a reliable turnkey job at the 25 to 50 pieces qty level
I can find several companies using Google, but after a couple of disasters, I now only want to deal with companies who are recommended by an actual user.
Anyone can recomend any good vendors?
PM me
I have a Pick and Place machine. my prices are reasonable. I currently assemble for Bean (on this forum) the AttoPilot. www.AttoPilot.com and the Air-Commander. www.air-commander.com
It's Only A Stupid Question If You Have Not Googled It First!!
Parallax Propeller P8X32 Education Board
For small runs I have done my own work though at some point I may have to source some of it out so I would like to learn from other's experiences.
Timothy D. Swieter, E.I.
www.brilldea.com - Prop Blade, LED Painter, RGB LEDs, uOLED-IOC, eProto for SunSPOT, BitScope
www.tdswieter.com
(Bear in mind, we are ONLY interested in turnkey sources.)
1) Ensure that vendor takes responsibility for PCB fab
2) Visit the facility, make sure its not a bucket shop
3) Vendor must use a PP machine for your job
4) Preferably, choose a vendor for whom small volume customers are important.
Problems we have had with manual assembly
1) IC's soldered in THE WRONG WAY ROUND
2) Capacitors, resistors soldered on to adjacent pads, 90 degrees out
3) Capacitors, resistors wrong value, sometimes by a factor of 10
4) Substituted connectors which were not mechanically compatible
in a complex board, it can take a day to find these problems
Our current vendor Optimum Design Associates, http://www.optimumdesign.com/
does a first class job, but at a first class price.
sounds like whomever you choose to do your fab should have some sort of ICT (in circuit testing), which means that the board will need pin accessable test pads if they use a bed of nails type fixture to do the testing with. we used hp3070's, and once up and running, they worked fine, but setting them up and building the test fixtures took some time, and might not be the best choice for small production runs. (we ran 200-500 pcb's per shift, 24 hours a day, for months on end)
just some thoughts.
After hand assembling the prototypes and verifying the functionality of my design, these people did a really nice assembly job and were easy to work with. HOWEVER! you have to be ready to have absolutely EVERYTHING documented and every little detail about placement, part numbers etc. ready to go.
They work well with shipments direct from Digikey. as well as ExpressPCB. you DO need to have a solder mask made ( they can help you with the process )
It's been about a year since I worked with them, but no complaints at all.
Ken Bash
" Anything worth doing... is worth overdoing. "
··············································· ( R.A.H. )
Tom
Tom
www.tdswieter.com
Labor only.
Tom
Tom
