My first Prop SMT board
I just got my first SMP Propeller board working!· Soldered everything by hand.· I wasn't completely sure I could, but it was actually pretty easy...
One big mistake was with the status LEDs for the FTDI chip.· I thought I could connect them through resistors to ground, but this doesn't work.· Seems the outputs are actually open collector, even though the datasheet says they can source as well as they sink...· So, I had to modify the board and run a jumper to VCC.
Other small problem was that the pads for the 28-PIN SSOP (FTDI chip) in ExpressPCB are only 7mm wide, when they really should be 9mm wide and so the pads don't stick out any from the chip.· This made soldering especially difficult...
One thing I'm doing differently is that I'm running the FTDI with 5V I/O...· That's why I have resistors in the RX/TX lines to the Prop.· I'm doing this because I have a project in mind that would need 5V to run, but want to turn it off with the sleep signal...
The miniUSB was easy to solder.
This uSD card socket was easy to hand solder.· Works without pullup resistors.
This board was mostly a test for my soldering skills.· That's why I left so much room around everything.· But, I do have a 2.5" TFT LCD to mount on the other side...· That's the next challenge...
It looks good !! but looks like you didn't use flux to sold the chips.
Try using gel flux, you'll found that is more more easy to sold any chip, and will look more professional.
Also to sold 0805 or 0603 smd's I prefeer almost not touch them while soldering, just use the flux and leave the component to get auto align in PCB, it's quiet difficult to learn but one you get it ..live is more easy.
Regards.
Alberto.
I did use sticky flux to hold the parts in place while I soldered...
With the flux pencils that sell DigiKey, you can get similar results as using the gel, you get solder all in one solder pass.
The difference between solder one by one and the another method is bigger.
To hold the IC parts you can only sold some opossite pins without any care, then the flux will repair all short circuits.
Sorry is very difficult for me to explain this process in English.
Regards.
Alberto.
· Emulators (Micros eg Altair, and Terminals eg VT100) - index
My cruising website is: ·www.bluemagic.biz
there's just not enough hours in the day though, to do everything I want to do lol [noparse]:D[/noparse]
Another interesting thing is that I mixed up the base and emitter connections on the NPN transistor that drives the RESet line...
But, it works anyway!
Since it looks like home made : ) sorry no criticisms, but i pay for 10 boards 2 sided with solderstop mask and print for parts with shipping 80-90 $.
And they are always perfect. And making soldering so much easier.
Best regards
Anubisbot
The uSD socket is Digikey# 670-1355-1-ND. I didn't hook up the detect switch...
