Propeller and OBD-II interfaces
Does anyone have experience interfacing a Prop (or BS2 for that matter) to the OBD-II interface on their car? I am specifically interested in the CAN flavor.
From another post there is the Microchip MCP2551 CAN Transceiver which seems to be an OBDII to RS232 converter. But I have found the ELM323 from http://www.elmelectronics.com/ which is an OBD-II interpreter. It looks like this should require less code on the Prop, but I am not certain.
I didn't see any objects in the object exchange, so I was looking for any insight from people that may have already looked into doing something with OBD-II. My main concern is that the protocol to run the OBD-II will require a lot more memory than can fit in the Prop RAM.
Any insights on interpreter versus dumb conversion would be...well...insightful.
http://forums.parallax.com/showthread.php?p=750908
Aka: CosmicBob
You simply RX and TX to and fro with FullDuplexSerial or the like. I connected a keyboard and a composite screen and I could type queries to the ELM chip, and it replied with the vehicle data. It worked quite nicely. I never really had time to take it much further than that. I planned to create a program with an infinite loop that continuously checked a set of parameters and feed to another cog to display that data.
The stumbling block I ran into is that I seemed to get responses in a different format depending on what type of vehicle I was connected to. It made it difficult to parse the data and extract the needed variables.
Brian
uController.com - home of SpinStudio - the modular Development system for the Propeller
PropNIC - Add ethernet ability to your Propeller! PropJoy - Plug in a joystick and play some games!
SD card Adapter - mass storage for the masses Audio/Video adapter add composite video and sound to your Proto Board
I'd really just like to monitor things like RPM and speed, and then compare that to the speed I am getting off the GPS module.
There is a sourceforge project called freediag I have been looking at...I just started, but it might be possible to reverse engineer the protocol from that code. If only someone would write a J1979 for Dummies book.
The following code successfully resets the ELM327/RS232 module every few seconds (I see the LEDs cycling and the reset command is echoed back to the Prop). However, I know that the module is supposed to send an identification on startup / reset, which I don't appear to see. The code seems to 'garble' the first message received (as if some bits aren't aligned) - have I missed something with the intialisation / use of FullDuplexSerial?
CON _clkmode = xtal1 + pll16x _xinfreq = 5_000_000 CR = 13 ' ASCII <CR> LF = 10 ' ASCII <LF> serXmit = 7 serRecv = 6 LCD_PIN = 2 'For AMC1602AR serial LCD on P14 LCD_BAUD = 19_200 'Baud rate for communication to AMC1602AR LCD is set LCD_LINES = 2 OBJ text : "vga_Drive" uart : "FullDuplexSerial" lcd : "Debug_Lcd_AMC1602" VAR Byte gps_buff[noparse][[/noparse]80], Rx, dataIn[noparse][[/noparse]100], ct, crt pub main uart.start(serRecv, serXmit, 3, 9600) ' Start the RS232 communications uart.rxflush ' Flush the buffer lcd.init( LCD_PIN,LCD_BAUD,LCD_LINES) ' Start the LCD display lcd.cls ' Clear the display text.start(16) ' Start the monitor text.out(00) text.str(string("TEST")) ' Place the text "TEST" on the monitor repeat longfill(dataIn,100,0) ' Empty the dataIn variable repeat while Rx <>= CR ' Continue to collect data until the end of the data Rx := uart.Rx ' Get character from Rx Buffer dataIn[noparse][[/noparse]ct++] := Rx crt := 0 repeat (ct - 1) text.out(dataIn[noparse][[/noparse]crt]) ' Display the data received on the VGA lcd.putc(dataIn[noparse][[/noparse]crt]) ' Display the data received on the LCD crt++ waitcnt(240_000_000 + cnt) 'Wait a while ATZ 'Send an ATZ Reset command pub ATZ uart.tx(65) 'A' uart.tx(84) 'T' uart.tx(32) ' ' uart.tx(90) 'Z' uart.tx(13) 'Carriage return text.out(13)▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔
Hugh - the thinking woman's Geoffrey Pyke.
does each manufacturer have their own protocol, or 'sub protocol' ?
> As it turns out it looks like the cheapest way to figure OBD II out is going to cost $300 to buy a copy of the HS-3000 book from SAE.
Well, if you get paid say $20 an hour and it takes you 16hrs to reverse engineer the protocol... no wait,·you'll also loose maybe $30 for the needed Excedrin Extra Strength
Does that book reveal the entire protocol, including different manufacturers?
I was in a Dodge shop the other week and overheard on of the mechanics/techs talking to their SnapOn Tools rep about 'getting the latest OBD with the·whatever attachments, and ... make sure it's got the latest flash memory.'·· You could see the ($)^($) in the reps eyes.·
Guys I think there's money to be made here if we could come up with a cool, cheaper -extensible- OBD interface device... I've had that in the back of my head for at least a year or so. But the dang thing would be complicated to support all the manufacturers/models. (Not to mention the state of the Auto industry!)
cheers
- Howard
( Who learned his old truck even had a computer once it stopped working after a small, arc welding repair ~~~ zap )
http://www.blafusel.de/obd/obd2_kw1281.html
Click on the British flag to translate to english.
For Porsche 964·protocal , it's the ISO 1914-1 first written in1989 and is prorietary. The stream of xmitting bytes·consists of an address byte sent at 5bbs connecting the the disignated ECU, followed by a sync byte, then your connected.· I suspect there's something similar to your car, especially if the manufacture date is around the time OBD wasn't standardized.
Kevin
Bad spellers of the world untie!
I'm playing with a Saab 9-3 Viggen, but haven't started with the ISO/OBD layer yet - I'm still tinkering with the RS232 portion. It doesn't help that:
* some responses have an additional '>' and carriage return after the initial response and CR
* my PC is inside, my car is outside, so I keep having to walk between the two!
