Prop Broadcast
I heard in the very early days that you could get the prop to broadcast over a short peice of wire, through the air to a TV.· ins anyone doing this?· Please help me understand what i need to make it work.
It's Only A Stupid Question If You Have Not Googled It First!!
Post Edit --
http://obex.parallax.com/objects/category/3/?page=4
Post Edited (PJ Allen) : 1/25/2009 4:38:00 PM GMT
http://forums.parallax.com/showthread.php?p=732122
Aka: CosmicBob
I had it running through the same resistors used for composite output, I didn't get a great output though.
For 8bc and graphics.spin you have to change two things.
Change pins to %001_0100
This sets pins 12, 13, 14 for broadcast instead of baseband.
Change broadcast to the frequency in Hz, for example, 55_250_000 for channel two.
You can use other frequencies. Use the video carrier frequency.
tvparams long 0 'status long 1 'enable long [b]%001_0100[/b] 'pins long %0000 'mode long 0 'screen long 0 'porch color long x_tiles 'ht long y_tiles 'vt long 20 'hx long 2 'vx long 0 'ho long 0 'vo long [b]55_250_000[/b] 'broadcast long 0 'auralcog
