Looking for company who can make custom membrane button boards for a project.
I am designing a new project that has a menu system and I was wondering if anyone knows a company who can build a membrane or tactile button board. I only want to order small quantities since my budget is extremely low. There are basically 4 buttons in a vertical line. The buttons need to labeled : Menu, Up, Down, Enter (or Save). I found a few companies on google, but the average cost was going to be $2000 + for 100 boards....ouch! If anyone has any links or companies I can call, I would greatly appreciate it!
Instead of a custom keypad, look into a custom adhesive overlay to stick on top of an off-the-shelf keypad.
www.microchip.com/stellent/idcplg?IdcService=SS_GET_PAGE&nodeId=2599
Also, Freescale has some new touch sensor chips that can be interfaced via I2C - all you need is a PCB with a plastic overlay.
Leon
Amateur radio callsign: G1HSM
Suzuki SV1000S motorcycle
I have used the Quantum touch chips which work very well. Quantum touch 60160 is a little hard to use in a mlf32 but its performance out of the box is very good. Something in their firmware creates a chip that takes the fooling around part out of using capacative touch.
I used cubbison to make my overlays. They did around 100 for about $300. Check out label companies as there are some that are cheaper if you don't need a window. These are essentially the same overlays that go on top of a membrane keypad. You will have to have some sort of cad/publishing program like Corel or Adobe as these companies may not want to mess with dxf etc.
Leon
You would use the AKS mode to eliminate false triggers. Quantum has a number of application notes. I am programming the QT60160 at the moment, they are more difficult for a home brew operation if you don't have experience with tiny SMT parts, plus there is quite a bit of code to get it setup and dialed. The 140 just requires you change out the caps to find the right sensitivity.
You could also try Cypress' line of capsense PSoC devices. A little more complicated, but much more powerful.
Also, another solution to the keypad, is the use of snapdomes under an overlay label. www.snaptron.com/domesmainxxzxqma297.cfm
Andrew Williams
WBA Consulting
IT / Web / PCB / Audio
Post Edited (WBA Consulting) : 1/26/2009 9:20:49 AM GMT
