Part # for crystal socket on Parallax Products
On the Propeller Demo Board and Propeller Protoboard and a couple other Parllax products I have seen a socket for the crystal. The socket is essentially a cup in a via that sits nearly flush with the board. I am looking to use something like that in on of my designs but I am having trouble searching for the right item. Does anyone have a lead on what the part is called and where I can get it from?
Thank you.
Timothy D. Swieter, E.I.
www.brilldea.com - Prop Blade, LED Painter, RGB LEDs, uOLED-IOC, eProto for SunSPOT, BitScope
www.tdswieter.com
Thank you.
www.tdswieter.com
www.cambion.co.uk/main/solder1.htm
I've used them for double-balanced diode mixers.
The above ones would be about right for crystal leads (0.43 mm).
Leon
Amateur radio callsign: G1HSM
Suzuki SV1000S motorcycle
Post Edited (Leon) : 1/23/2009 7:16:17 PM GMT
www.tdswieter.com
Leon
http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=ED5044-ND
Chris Savage
Parallax Engineering
www.tdswieter.com
Leon
· -- Carl, nn5i@arrl.net
