Beginning Robotics: BOE-Bot or Sumo-Bot?
Hey everybody,
I'm very interested in robotics and would like to start learning. I don't have any electrical engineering experience but I do have some programming experience. I'm planning on starting with a kit. Would you recommend the BOE-Bot or Sumo-Bot. What are the advantages/disadvantages?
You will learn so much as you work you way through the book.
Have fun!
Whit+
After that, voila, you've got yourself a HOBO-BOT. (HOmework BOard - roBOT)
The BOE-BOT is the most flexible robot, I have ever built you know. You can turn it into just about anything.
Enjoy, and...
BWIN ON DA POWAH WIFIN U!!!
Rev 06 is now on a slab in the lab. Hopefully in a few weeks, we'll have a thunderstorm and I can hook up the electrodes and bring it to life.
What kind of Tank Treads are those in the last two pics?
Whit+
not sure if any of the Sumo-bots accessories are sold separately
1. Add the QTI Line Follower kit - mount as far forward and to the sides as possible. This will be used to detect the edge of the ring. This is the same sensor used on the sumobot.
2. Fabricate a front scoop to push your opponent. You should be able to make a reasonable scoop from heavy sheet styrene.
3. Program for sumo wrestling.
Note: since you have more exposed side with the BOE-BOT, you might want to paint it to strike fear into your opponents.
What is the advantage of the QTI Line Follower kit over a simple photoresistor?
Thanks for the reply. Sorry it took me so long to say thanks! The treads look great. I probably should have recognized them.
Whit+
