Infrared Thermometer Module... Parallax?
Hi All,
I just ordered and received my first MLX90614 Infrared Thermometer Module, Parallax Item Code #28040. After downloading the documentation for it (see below) I see that it's available in two field of view versions... 90 degrees(what I bought) and 10 degrees - Parallax Item Code #28042. The 10 degree field of view would much better suit my project so I have the following questions:
1. I don't find the 10 degree field of view module in the Parallax store... is it available? When may it be available?
2. Can I shield the view of the sensor on the module I have by having it 'look' through a piece of rigid tubing at the area to be measured and still get a reliable result? Will it average the temperature of the tubing walls into the result? I have not tried or tested this just in case I have to return this module for exchange with the narrow FOV version, I thought it best to ask first.
I should have looked into the documentation before the purchase.
Thanks for the help,
Tim
Module Documentation: http://www.parallax.com/Portals/0/Downloads/docs/prod/sens/28040-28042-IRThermometer-v2.0.pdf
Post Edited (Tim-M) : 1/21/2009 6:44:34 PM GMT
Tim
It also includes this note" Parallax is using Melexis P/N MLX90614ESF-AAA-TO-39, the single zone infrared thermometer sensor.'"
Aka: CosmicBob
Tim
The new sensor is being released this afternoon. You can find it by entering its stock code (#28042) into the search window. This sensor is currently available for purchase and any links should be updated. I hope this helps. Take care.
Chris Savage
Parallax Engineering
Update URL:
www.parallax.com/Store/Sensors/TemperatureHumidity/tabid/174/ProductID/539/List/1/Default.aspx?SortField=ProductName,ProductName
Aka: CosmicBob
Tim
Like I wrote to Jim, I love being a Parallax customer and spread that word where ever I go... it's the least I can do. Parallax understands the value this has and that is so refreshing!
Thanks Jim and the rest of the staff for making my day.
Tim
