Looking for a source for a low cost wave soldering or method to paste solder co — Parallax Forums
T&E EngineerT&E Engineer Posts: 1,396
edited 2009-01-26 08:33 in General Discussion
How does one solder semi-large quantities (50-200 or possibly more) of components (DIP to start - surface mount design change later) to PCBs without spending tons of time hand soldering. Is there an outsource method or is it better to invest in equipment? What about a baking oven or wave soldering which sounds expensive. What is used for something like this - or do we just hand solder the parts on. I have about·100 or·so parts·on the main PCB and 10 or less parts on the 2 other·supporting PCBs.
  • LeonLeon Posts: 7,620
    edited 2009-01-22 14:02
    Quantities like that are best done by a specialist company. The SM design will need a stencil for the solder paste.
    Leon
    Amateur radio callsign: G1HSM
    Suzuki SV1000S motorcycle
  • Carl HayesCarl Hayes Posts: 841
    edited 2009-01-22 17:40
    I would hope to see this thread expand into a general discussion of PCB soldering.· I need to learn, and perhaps others are interested in learning too, how to manufacture -- that is, make by hand -- complex PCBs in small quantity, including especially SMT devices.
    But even through-hole PCBs can be a bear to solder by hand, one pad at a time.· Might the methods used for SMDs·(convection ovens, etc.) be equally good for through-hole stuff?· Many of us, I imagine,·have never used those methods and it's time to learn.
    Surely there's some articulate expertise here on these fora.
    · -- Carl, nn5i@arrl.net
    edited 2009-01-22 18:15
    Solder paste isn't suitable for through-hole parts, so an oven can't be used.
    Some factories in China use a large solder bath instead of a wave-soldering machine. The unfortunate workers hold the boards in tongs and wipe them across the surface of the solder. They are highly skilled, of course, and get the speed and depth just right for reliable solder joints.
    Toasting ovens work well for surface mount assembly, especially if a suitable controller is used to get something like the correct temperature profile. Embossing heat guns are popular, and work quite well. I use a Metcal system (STSS power unit and MX-500 handpiece and cartridges) for through-hole and surface mount assembly.
    Leon
    edited 2009-01-23 03:45
    Interesting. Heat gun. I assume that's a hot air gun. How do you stick the devices to the board so the hot air won't blow them away before heating them sufficiently to melt solder? Somehow I doubt you use a gazillion tiny clamps. Some kind of special glue?· Of course the same necessity would arise for using·a convection oven, too.
    Post Edited (Carl Hayes) : 1/23/2009 3:50:23 AM GMT
  • metron9metron9 Posts: 1,100
    edited 2009-01-23 04:01
    I use a device called PCSS/2 from Italy. Attached pic
    Add a 1/4 inch tab on the top and bottom. You load the parts on the board and then put a foam top down on top that holds all the parts to the board. It snaps in place, you flip the whole thing upside down and Solder the back side, snip off the leads and you are done.
    I typically load all the smallest parts first, resistors and diodes, solder them and then do the larger parts.
    So in one evening the 42 boards get done shown here.
    Now remember I have run my own multi million dollar screen printing business since·I was 15 years old (it was just thousands back then though) and I am 51 today so·I know something about production.
    Think Inside the box first and if that doesn't work..
    Re-arrange what's inside the box then...
    Think outside the BOX!
    Post Edited (metron9) : 1/23/2009 4:08:34 AM GMT
    1632 x 1224 - 1M
  • Cole LoganCole Logan Posts: 196
    edited 2009-01-23 04:13
    THat actually looks like it would be a pretty easy set up to make for a DIY. Biggist part would be finding a good frame material for hopefully that would already have the goove in it.
    edited 2009-01-23 05:18
    Well, really my query about how to hold stuff in place was meant to apply to SMT devices, which I assumed (perhaps na
    edited 2009-01-23 05:34
    Dip soldering is the way to go for small-scale production of through-hole boards. The equipment is cheap to buy, and the technique couldn't be simpler. This is how I used to do it:
    ····1. Heat up the solder bath to the correct temp. (There are temp-controlled solder pots available in all sizes for this.)
    ····2. Using Kapton tape, mask off any exposed metal on the bottom of the board that should not get solder.
    ····3. Insert all the parts into the board.
    ····4. Spray adequate flux on the bottom of the board to wet it and all the leads.
    ····5. Hang board over a hot pancake griddle to dry the flux.
    ····6. Dip board into molten solder. Let it sit there a couple seconds or so, then pull it out. This step requires almost no precision. The solder is so dense and has so much surface tension, that the board will float on top if you let it.
    ····7. Remove the Kapton tape, clip the leads, and clean off the residual flux.
    ····8. If the board is panelized, snap it apart, and dress the rough edges with a file or sandpaper.
    You'll be amazed at the clean solder fillets you can get — better than you could ever get by hand. 'And all this without a huge investment in wave-soldering equipment.
    edited 2009-01-23 06:21
    Carl Hayes said...
    I would hope to see this thread expand into a general discussion of PCB soldering. I need to learn, and perhaps others are interested in learning too, how to manufacture -- that is, make by hand -- complex PCBs in small quantity, including especially SMT devices.
    Carl,
    you might have a look at some of the educational videos on Sparkfun.
    www.sparkfun.com/commerce/tutorials.php
    Click on "Surface mount soldering tutorials."
    I've been wanting/needing to learn this sort of thing, too, but.... someday maybe....
    edited 2009-01-23 06:26
    Back when I cast my own handgun bullets, I actually owned a small solder pot, though it was called a lead pot.· It would have been big enough for the small PCBs I make· for myself nowadays.· Haven't owned one for years, and I'm not thrilled with the idea of inhaling that much lead vapor anyway.
    I ask again, though -- how do you affix, say, tiny SMD resistors and such to the top of a PCB before soldering?· Just set them in place?· Is the solder paste, perhaps, an adhesive before it gets melted?· They're so tiny, surely they'd blow away if they were held merely by gravity.· Even the handling necessary to place the PCB in a toaster-oven must surely require gluing them somehow.· How?· And the bigger stuff, like IC packages with zillions of tiny pins (solder tabs), must be prevented from shifting even slightly.· How?
    edited 2009-01-23 06:43
    ElectricAye said...
    Carl Hayes said...
    Carl,
    Well, that was instructive, though minimally so.· How do you do it with an oven?· The techniques illustrated are OK for one component at a time, I guess, but very slow -- and the whole idea of SMT is to get lots of components on a PCB.
    edited 2009-01-23 06:48
    Carl,
    The paste holds them in place long enough to zap in the toaster oven. Positioning is critical, of course, but the solder's surface tension helps to center parts that are a little off. I use a syringe for the solder paste and non-magnetic tweezers to set and nudge the parts into place. Inevitably, there are solder bridges to suck up, but copper braid makes quick work of those. For larger-than-one-off runs, Advanced Circuits will sell you a mylar paste mask that you can use to squeegie the paste onto the board. I know of one person who makes his own mask with a laser engraver.
    edited 2009-01-23 07:51
    Thanks, Phil. I think I'll start looking for a convection oven, or make one. There was a thread here a while back in which someone or other described using a Stamp, or maybe it was a Propeller, to build a temperature-profiled convectiion oven out of a kitchen appliance (toaster oven). But you have provided a key item of information that was missing. Again, thanks!
    edited 2009-01-23 10:42
    Carl Hayes said...
    Interesting. Heat gun. I assume that's a hot air gun. How do you stick the devices to the board so the hot air won't blow them away before heating them sufficiently to melt solder? Somehow I doubt you use a gazillion tiny clamps. Some kind of special glue? Of course the same necessity would arise for using a convection oven, too.
    The air flow isn't very high so the parts stay put. The solder paste helps, of course.
    Leon
    edited 2009-01-23 14:34
    Carl said...
    This months Nuts & Volts Magazine "Surface Mount Soldering: Using The Tools You Probably Have On Hand Already. "
    www.nutsvolts.com/index.php?/magazine/
    Aka: CosmicBob
    edited 2009-01-23 17:36
    The Zephrtronics rework stations use a heat gun ("fountain") blowing up from the bottom side of the PCB to heat it and the SMT components uniformly to around 150 degC. The PCB is held horizontal on a rack. Once preheated, you use a hot air pencil pointed down from the top to reflow the solder at around 250 degC. That is fine for small boards and works best for small components. It creates a good temperature profile. The preheat from the bottom does not blow away the SMT components on the top side, but it does activate the flux in the solder paste and hardens it so that it glues the components in place. The hot air pencil from the top takes some practice, to set the air flow so that it does not blow away or tombstone the components.
    The Zephrtronics stations are $$$, but it seems to me something like that could be made DIY.
    Things are much more difficult with no-Pb solder, due to the higher temperatures and lower surface tension. In my opinion, I would always send out to a professional assembly house any complex PCB that has 100 parts and where the board is to be assembled in more than prototype quantity and for sale. They have the really top notch equipment for solder stenciling, pick and place, and reflow, and also they have the experience to get uniform and reliable results when a board has differrent sizes of components and even SMT on two sides.
    Tracy Allen
    www.emesystems.com
    edited 2009-01-24 05:06
    My boards are one-off, Tracy. But I have learned much from this thread -- much that seems nearly unavailable otherwise. It still looks to me as if a toaster-oven-with-fan and temperature-control-with-a-stamp would be most practical for me, especially since I'm an impecunious retired guy.
    edited 2009-01-24 11:38
    This sort of stuff gets discussed all the time on the Yahoo Homebrew PCB forum.
    Leon
  • Erik FriesenErik Friesen Posts: 1,071
    edited 2009-01-24 13:16
    I have been doing a little toaster oven stuff lately. The most important thing in a toaster is a fan inside. Otherwise there are hot spots and infrared heating that make it hard to get consistent reflow. I have been using Kester em907 noclean pb free with good results. I don't have it microcontrolled at this point but I just use a oven thermometer and shut it down when the solder melts. Pololu makes plastic solder stencils for $30 that seem to work OK for me.
    edited 2009-01-24 17:26
    Erik,
    Did your oven come with the fan, or did you add one? The reason I ask is that my little IR unit lacks a fan, and I'd like to add one. But I'm not quite sure where to find one that will survive the temps.
    edited 2009-01-24 18:12
    I bought a cheap one without a fan, but had hot spot problems. I found a toastmaster quickcooker at goodwill for $15. Modified the fan so it runs continuous. With a board 1 1/2" from the element there is no problem now.
    The motor is not inside the oven. There is a hole that the shaft pokes through.
    edited 2009-01-25 10:07
    Erik,
    Where did you mount the fan, and in which direction is the airflow aimed? I typically solder really small boards and can just picture them blowing off the rack.
    edited 2009-01-25 11:11
    Fan forced: Surface Mount Device (SMD) reflow toaster oven
    www.homanndesigns.com/SMDToasterOvenProject.html
    Aka: CosmicBob
    edited 2009-01-25 13:57
    I should have made myself clearer. The second oven I bought had one built in. The motor is mounted in the compartment with the controls.
    The fan is set up like the picture. It is a centrifugal type so there are holes in front of the fan for intake and two holes on the side that exhaust. The original design had the motor pwm'd for different food functions but shut off the motor when the coils quit. The coils have too much residual heat to allow that.
    I am soldering 60mmx70mm boards without them or their parts blowing around but I think it would work running a bit slower.
    bmp
    183K
    top.bmp 182.7K
    Lots of good feedback on the question. Here's my 2 cents...
    Regarding through hole soldering similar to SMT practices. Yes, it is completely possible but expensive and complicated. The process is typically referred to as "Pin in Paste". You screen print paste into the holes and above the annular ring of through hole locations, place the TH parts, and reflow with a standard reflow profile for the paste in use. There are several limiting factors to this process such as process specific board design, paste volume determination, and components that must be able to withstand reflow temperatures.
    For quicker TH soldering, I would focus on speeding up your current TH soldering methods. Designing custom ESD foam flip boards is ideal for your situation. Having a board with properly placed foam to hold your parts in place will allow you to load the board completely, flip it, then solder then entire board without additional part handling.
    From a CM standpoint, your board would probably be run through a wave soldering process. Either a typical wave, or a selective, depending on your board and/or panel layout. Selective example from ACE Protech www.ace-protech.com/products/kiss_102.asp
    As for SMT, solder pastes are rather tacky and will hold passives in place even when the board is held upside down without reflow. When parts are placed by pick-n-place machines, they are placed "into" the paste so that the tackiness of the paste will hold the parts prior to reflow. If you have ever seen a fast pick-n-place in action, you will see that the force created by the XY table movement during placement is much greater than the air movement by a small fan, embossing gun, or hot air pencil (unless you are using them improperly). (example: That's a Fuji CP-6 that's rated at 40,000 cph (components per hour). I used to manage 6 lines with 10 of them at the former Packard Bell motherboard shop in Sac. I miss seeing those machines everyday, poetry in motion)
    Andrew Williams
    WBA Consulting
    IT / Web / PCB / Audio
    Post Edited (WBA Consulting) : 1/26/2009 8:41:18 AM GMT
