Beginner robot
· Hi, I've recently started taking robotics as my hobby (5 days ago). I'm a 13 year old student
with limited finances and time so I was wondering how I should start out my robotics
hobby. I 've read a couple of beginner books by David Cook and Gordon McComb (Im sure you know them)
but they said that if you are a complete newbie, you should start out with a
lego mindstrom NXT kit or a parallax boe-bot.
The lego didn't appeal to me very much so I decided to go to the parallax route.
So... my real question is, how should I start my robot hobby career?
Should I go the lego NXT route, the parallax boe bot route, or some other way?
Thank you!
ps. also, if I should go the parallax boe bot way, which parallax boe bot should I get?
···· I mean, there's so many of them!
Thank you!
Good Luck!
Jax
If a robot has a screw then it must be romoved and hacked into..
Personally, I don't like the Lego mindstorms for two reasons. First, they remove all the electrical engineering from your sight. You hook it up, and it's guaranteed to work. I like to be able to hook anything up and write some code, and it does something new and exciting. This brings me to reason two: I don't like the programming environment. While a GUI for programming is good for small children or professionals well into their career, if you really want to learn how to program hard coding is the best way to go.
In summary, the BOE-BOT is your best choice. If the price is too high, then a BOE with a BS2e will get you started (don't forget some components like LEDs and Buttons!).
1) $60 cheaper
2) Comes fully assembled and ready to work
3) Relatively robust
4) Has simple GUI to get you going and teach PBASIC by example
5) As far as my LIMITED understanding goes it has light sensors the boe doesn't (although the BOE has whiskers)
The CON is that ELECTRONICALLY it is nowhere near as flexible (you have what you have)
For us the scribbler was still the best bet - we figured it was 70-30 that he would fall in love with the coding more than the electronics - and if he does fall for the electronics the $60 we saved gets us a long way towards getting an electronics kit ....
David
Then can you tell me which parallax boe bot would be the best?
I found out that there are about 3 types:
1. USB version
2. Full Serial Pack
3. Microsoft Computer Base (or something like that/the 220dollar one)
Please tell me the pros and cons of each.
I'd go with #1.
"THE ONLY TRUE WISDOM IS IN KNOWING YOU KNOW NOTHING." - SOCRATES
Goog Luck!
Post Edited (LilDi) : 1/21/2009 4:47:29 PM GMT
The Boe-Bot is an excellent place for the beginner to get started, especially if you want to focus on building simple circuits and programs. As GWJax mentioned, most of our books are available online for free. In order to get better acquainted with the BASIC Stamp programming language, we recommend you begin with our What's a Microcontroller book. That way, you can use the parts that come with the Boe-Bot to complete 26 of the 44 activities in the What's a Microcontroller text, and this will give you a good foundation before programming your Boe-Bot.
If you would like to get an idea of the things you can accomplish with the Boe-Bot, you can also download the Robotics with the Boe-Bot text.
I hope this helps get you started! Best of luck!
Jessica
Jessica Uelmen
Education Department
DGSwaner
"When in doubt, use C4" - Jamie Hyneman, Myth Buster
And yes, these Boe-Bot kits all do have light-sensing·photoresistors like the Scribbler, a pair of photoresistors to build a light-navigation project on the breadboard.· There are also whisker touch sensors, and infrared sensors for object and distance detection.
Once you have made your way through the basics, there are all kinds of additional hardware and extra sensors you can add, and more activities posted online in the Stamps in Class Mini-Projects Sticky Thread.· Check it out, and you can see some Boe-Bot videos for some of the experiments.
Have fun!
-Stephanie Lindsay
Editor, Parallax Inc.
And of course...
BWIN ON DA POWAH WIFIN U!!!
