MAX232 (RS232) based Serial to Propeller interface - how safe ?
Although I have built the Parallax Serial to Propeller Interface which works great in place of my USB propplug, I came across a MAX232 Serial to Propeller circuit (WWW.tdus.de) incoporated a Prop D-40 board.
Question: Are the signal levels safe for the Propeller. I seem to remember that for 3.3V circuits, they recommend to use the MAX3232 ic which is the 3.3 volt version of the chip.
I can only find MAX232 chips here locally unless I order·the MAX3232·from the US.
The max3232 though is the neater solution. I got some from http://www.futurlec.com I'm in Australia and Futurlec ship out of Thailand so their shipping time is about 8 working days whereever you are.
$1.90 each, postage for small quantities is a flat $4. I buy about 2 orders a week because their shipping is so low you can afford to get a few test chips then come back and get more if they work fine.
Post Edited (Dr_Acula (James Moxham)) : 1/21/2009 7:37:26 AM GMT
Regarding the voltage levels have a look at the hardware stickies in this forum: 'HOW TO SAFELY INTERFACE A 5V SIGNAL TO THE PROPELLER?' I would not connect it directly to RS232. Stay with the MAX232 or build a converter yourself from two transistors and a few resistors.
virtuPIC
Airspace V - international hangar flying!
http://www.airspace-v.com/ggadgets for tools & toys
I have included pdf's for both.
The ST Microelectronics option is available from Radionics - radionics.rs-online.com/web/
Specifically - radionics.rs-online.com/web/search/searchBrowseAction.html?method=getProduct&R=4152111
The Intersil version is available from Farnell - www.farnell.com/
Specifically - ie.farnell.com/intersil/icl3232cpz/rs232-transceiver-3232-dip16/dp/1201546
Incidentally I have used both without issue.
Hope this helps..
John
Edit: As a reference I have added a·Pdf of the the RS-232 PropStick schematic as used by parallax.
Rgds,
JT
'Necessity is the mother of invention'
Those who can, do.Those who can’t, teach.
Post Edited (QuattroRS4) : 1/21/2009 10:29:07 AM GMT
The links and files are very helpful
However, I would put diodes in parallel to the resistor between basis and emitter of the transistors taking RS121 as inputs. Haven't looked up the datasheets but usually they don't like negative VBE.
