Some serial comms and variable sizes
I have been trying to use chip gracey's full duplex serial and the Extended _FDSerial, and I am having some success.
·In another thread a few guys helped me to send and receive, and I have the code I have been using here.· It is stuff that I got from them that I have modified somewhat.
the questions I have are:
I defined the Variable "MyVariable" as a long... why is it able to transmit so much in the Main
Is it even using the "MyVariable" that I defined in the VAR block?
SER : "Extended_FDSerial" VAR long MyVariable PUB Main MyVariable :=(string("This is it oh yes it is furthermore how much stuff will this vatiable hold??")) ser.start(31,30,0,38400) dira[noparse][[/noparse]15] := 1 ' output port to also flash an LED for example outa[noparse][[/noparse]15] := 1 ser.str(string("Communication with propeller", $0D)) ser.str(MyVariable) waitcnt(10_000 + cnt) ser.tx(13) ser.tx(10)
John Abshier
Now I'm trying to recieve some serial transmissions...
I was hoping to see the led's connected to 17... 21 change state according to the input character.
it definately does something... 21 will go on and off when transmissions are recieved but that's it.
No patterns as·I expected.
EDIT: I realized what was wrong as soon as I posted this... seting dira[noparse][[/noparse]17..21] :=%11111· did the trick.
Post Edited (realolman) : 1/20/2009 11:33:32 AM GMT
another testing method is to just send back what you received
best regards
Stefan
