QTI Sensor Differences — Parallax Forums
SRLMSRLM Posts: 5,045
edited 2009-01-20 04:09 in General Discussion
Hi,
I was working on making a pair of wheel encoders from the QTI sensors, and I noticed something interresting.When I had both hooked up to the BS2 and ran the code, one would give a black value at about 300, while the other would give something at least a 3800, and both would give really big values for the holes in the wheel (empty space). It's always SenseRight that gives the smaller value. I've determined that the hardware must be the same, since I switched the leads and got the same problem. So, what's not right with my code? It's pretty much standard Parallax issue sample code.
' {$STAMP BS2e}
' {$PBASIC 2.5}
LeftLineSnsrPwr PIN 13
LeftLineSnsrIn  PIN 12
RightLineSnsrPwr PIN 11
RightLineSnsrIn  PIN 10
ClrEOR CON 11
SenseLeft  VAR Word
SenseRight VAR Word
  DO
    GOSUB Distance
    DEBUG HOME
    DEBUG "Encoders Test:", CR
    DEBUG DEC senseLeft, CR, DEC SenseRight, CLREOL
    PAUSE 100
 LOOP
Distance:
  HIGH LeftLineSnsrPwr
  HIGH LeftLineSnsrIn
  PAUSE 1
  RCTIME LeftLineSnsrIn, 1, SenseLeft
  LOW LeftLineSnsrPwr
  LOW LeftLineSnsrIn
  PAUSE 1
  HIGH RightLineSnsrPwr
  HIGH RightLineSnsrIn
  PAUSE 1
  RCTIME RightLineSnsrIn, 1, SenseRight
  LOW RightLineSnsrPwr
  LOW RightLineSnsrIn
RETURN
    edited 2009-01-18 12:30
    Strange you have a difference by a factor of 10 and a bit,·perhaps there is a component value difference on your breadboard between each sensor and the BS2?
  • SRLMSRLM Posts: 5,045
    edited 2009-01-19 22:24
    Hmm. No, I've hooked each up as an identical duplicate. I've also added another three sensors that are to sense lines, so now I have a total of five. When I did that and added the additional code, I got a bunch of large, four digit numbers that didn't seem to have any relevance to the real world. However, when I changed the DEC statement to a DEC5, they work perfectly. Something's fishy...
      DO
        GOSUB Encoders
        GOSUB LineSensor
        DEBUG HOME
        DEBUG DEC5 SenseLeftWheel, CR, DEC5 SenseRightWheel, CR
        DEBUG "Line Sensor Test: ", CR
        DEBUG DEC5 SenseRightLine, CR, DEC5 SenseCenterLine, CR, DEC5 SenseLeftLine
        PAUSE 100
    LOOP
    Encoders:
      HIGH LeftWheelSnsrPwr
      HIGH LeftWheelSnsrIn
      PAUSE 1
      RCTIME LeftWheelSnsrIn, 1, SenseLeftWheel
      LOW LeftWheelSnsrPwr
      LOW LeftWheelSnsrIn
      PAUSE 10
      HIGH RightWheelSnsrPwr
      HIGH RightWheelSnsrIn
      PAUSE 1
      RCTIME RightWheelSnsrIn, 1, SenseRightWheel
      LOW RightWheelSnsrPwr
      LOW RightWheelSnsrIn
    RETURN
    LineSensor:
      HIGH LeftLineSnsrIn
      PAUSE 1
      RCTIME LeftLineSnsrIn, 1, SenseLeftLine
      LOW LeftLineSnsrPwr
      LOW LeftLineSnsrIn
      PAUSE 1
      RCTIME RightLineSnsrIn, 1, SenseRightLine
      LOW RightLineSnsrIn
      HIGH CenterLineSnsrPwr
      HIGH CenterLineSnsrIn
      PAUSE 1
      RCTIME CenterLineSnsrIn, 1, SenseCenterLine
      LOW CenterLineSnsrPwr
      LOW CenterLineSnsrIn
    RETURN
  • Beau SchwabeBeau Schwabe Posts: 6,574
    SRLM,
    Just for kicks, try to define LeftLineSnsrPwr, LeftLineSnsrIn, RightLineSnsrPwr, and RightLineSnsrIn with 'CON' instead of 'PIN' and see if that makes any difference.
    Beau Schwabe
    IC Layout Engineer
