Code Optimization — Parallax Forums
Code Optimization
KyeKye Posts: 2,200
edited 2009-01-19 21:35 in Propeller 1
Hello, all I've been busting my head on how to do something in asm much more simply, but I just can't seem to get it done.
Here's the code..
                        muxnz   keyBuffer,          #1                  ' Backup Z flag.
                        cmp     keyArrayCounter,    #2 wz               ' Wait a little while to synchronize.
if_nz                   cmp     keyArrayCounter,    #6 wz               '
if_nz                   cmp     keyArrayCounter,    #10 wz              '
if_nz                   cmp     keyArrayCounter,    #14 wz              '
if_nz                   cmp     keyArrayCounter,    #18 wz              '
if_nz                   cmp     keyArrayCounter,    #22 wz              '
if_z                    waitcnt keyTimeBuffer,      clockWait           '
                        test    keyBuffer,          #1 wz               ' Restore Z flag.
Basically, I need to use waitcnt for a state machine at specific times·in my code. The piece above is run inside a loop that loops 26 times. Every four loops I need to execute the waitcnt which is what this code does.
Now, I want to make it more optimized by using the c flag only so I don't need to backup the z flag since I'm using it within the loop. The problem is however, that there's a sweet spot. The code above executes that sweet spot. To say, waitcnt must only be executed on the 22, 18, 14, 10, 6, 2 parts in the loop. Note that the loop counts down from 26 so the execution of the coditional for 2 is last and 26 is first.
I can't seem to figure out how to do this with the c flag...
Any ideas?
Nyamekye,
  • lonesocklonesock Posts: 917
    edited 2009-01-19 19:30
    Untested, off the top of my head:
    mov tmp, keyArrayCounter
    sub tmp, #2
    and tmp, #3
    tjnz tmp, #skip_pause
    skip_pause
    lonesock
    Piranha are people too.
  • KyeKye Posts: 2,200
    edited 2009-01-19 19:43
    Wow, I think that will work, thanks!
    Any other ideas anyone?
    Nyamekye,
    edited 2009-01-19 19:50
    YW, and maybe this will work:
       rev tmp, #30
       djnz tmp, #:skip_pause
    :skip_pause
    Reversing the lower 2 bits of tmp will zero out all upper 30 bits, and will leave a 1 in tmp if the original value would have been a 2. Then the DJNZ jump to :skip_pause if the value of tmp was not 1.
    lonesock
  • mparkmpark Posts: 1,322
    edited 2009-01-19 21:03
    Wow Lonesock! Nice one!
    Thanks.
    * bows *
    [noparse][[/noparse]8^)
    lonesock
