assembly cmp help — Parallax Forums
assembly cmp help
mctriviamctrivia Posts: 3,772
edited 2009-01-19 08:50 in Propeller 1
  cmp       ulMSec,ulDayLength              'See if day done
  if_b  jmp       :updateTime                     'If day is done jump to end of routine
The manual says if ulMSec is less then ulDayLength then c=1
if c=1 then if_b should be true and execute command.
ulDayLength=86_400_000
ulMSec will almost always be less the that. why does the line after this execute every time?
  • ColeyColey Posts: 1,130
    edited 2009-01-19 08:06
    Hi mctrivia
    It's because you haven't indicated which flag to set.
    try
    cmp       ulMSec,ulDayLength  wc            'See if day done
    Here the C flag will be set if ulMSec is less than ulDayLength
    regards,
    Coley
    PropGFX - The home of the Hybrid Development System and PropGFX Lite
    edited 2009-01-19 08:21
    ok that works but for some reason it resets to a value other then 0?
                  'run every day
                  mov       ulMSec,#0
    edited 2009-01-19 08:24
    It would be easier to help you if you showed the whole of this asm routine you are trying to debug... smile.gif
    edited 2009-01-19 08:27
    here it is
    DAT
                  org       0
    TimeKeeper    mov       cnt_value,cnt                   'prepare for initial waitcnt
                  add       cnt_value,cnt_ticks
                  'run every ms
    :loop         waitcnt   cnt_value,cnt_ticks
                  rdlong    ulMSec,ptrToUlTime              'Copy sec over
                  add       ulMSec,#1                       'Add 1 to MSec
                  'run every day
                  mov       ulMSec,#0                       'Set Time to midnight
    {              rdlong    ulDat,ulDate                   'Copy days over
                  add       ubDay,#1                        'Add 1 day
                  mov       ulTemp,#months+ubMonth
                  'have not figured out how to do calendar yet
                  'finish up
    :updateDate   wrlong    ulDat,ulDate                    'Update the date
    :updateTime   wrlong    ulMSec,ptrToUlTime                   'Update the time
                  jmp       #:loop
    'Locale Time Value
    ulMSec        long      0
    ptrToUlTime   long      0
    'Locale Date Values
    ulDat
    uwYear        word      0
    ubMonth       byte      0
    ubDay         byte      0
    'Lenght of Month Table
    months
    january       byte      31
    february      byte      28
    march         byte      31
    april         byte      30
    may           byte      31
    june          byte      30
    july          byte      31
    august        byte      31
    september     byte      30
    october       byte      31
    november      byte      30
    december      byte      31
    'constants
    zero          long      0
    ulDayLength   long      86_400_000
    cnt_ticks     long      80_000
    cnt_value     long      0
                  fit       496
    edited 2009-01-19 08:31
    Probably your jump should be
    jmp #:updateTime
    Prop Tools under Development or Completed (Index)
    http://forums.parallax.com/showthread.php?p=753439
    My cruising website http://www.bluemagic.biz
    edited 2009-01-19 08:48
    that was it thanks
  • AleAle Posts: 2,363
    There is no access to bytes or words in COG assembly. You can only access longs and they will be long aligned because all addresses are long aligned with long granularity:
    Address 0 is the first long
    Address 1 is the second long.
    There is no byte granularity or word.
    To access ubDay I'll do this:
       mov  temp, ulDat
       shr  temp, #24   ' temp has now ubDay
       mov temp, ulDat
       shr  temp, #16
       and temp, #255    ' temp has now ubMonth
    I'd recommend you download pPropellerSim (from sourceforge.org/projects/ppropellersim) and test them through.
