Problem With Servo Controller
I connected the power on my Servo Controller, turned On the switch on the servo controller, and killed a 4x20 LCD that was connected to the same 5v supply line. Another 4x20 LCD on the same 5v supply blanks out, but recovers (on system power off/power on).
There's nothing else connected to the Servo Controller, just the ground and the +5v. The 5v comes from a PC power supply, and reads exactly 5v on my meter.
Can anyone tell me what's going on? I'm about to use my sledgehammer on the Servo Controller....
John Burrow
San Diego
John Burrow
San Diego
Thanks for the suggestion.
The Servo Controller is mounted on standoffs above a non-metallic (essentially wood) surface. But I'll go try·your suggestion·anyway.
I measured the current flow on an old analog meter, and I see a 'kick' then it settles down to almost nothing.
Also, what would cause my LCD to burn out?
Thanks, John
Chris Savage
Parallax Engineering
