ldo regulator question
http://www.national.com/ds/LM/LM1117.pdf
so im looking at using this regulator...
the 3.3V fixed output version
sot-223
i see 4 pins....
Input
Output
ADJ/GND
and VOUT
input is the input obviously which will be·5v·im getting this from rc reciver
ADJ / grnd obviously ground
what pin will be the 3.3 out· the output or the Vout
I dont have the part so cant test it but trying to layout· a board right now.
With say a 7805 there is just gnd, input, and output, but based on the this regulator the datasheet leads me to believe i should use the vout instead of the output... im confused [noparse]:([/noparse]
any tips woudl be appricated so i can add the caps and finish up the board design.
Thanks Jesse
sot-223
i see 4 pins....
Input
Output
ADJ/GND
and VOUT
Thanks Jesse
SOT-223
1- GND
2- VOut (Large pin is also VO)
3- VIn
At first I used the variable version with excellent results (and also LM317), but one must add two resistances. Now I have LD1117S33TR, for the Propeller and to repair monitors LCD.
according to what i can make out on the specs its seems the drop out voltage is about 1.2 would should be fine for 5 volts i would think no? ill check out the st regulator thought now.
