Suggestions needed for interfacing a Prop Plug to a metal enclosure
Hey everybody,
I'm interested in transforming my prototype from the "Lawrd ha'mercy it ain't nothin but a wig of wires!" stage to the "Yep, it's all inside that box" stage and I'm not at all familiar with the different types of electronic connectors. So can anyone please suggest a part number, source, etc. of a plug that will fit nicely through a metal enclosure so that I can plug in a Prop Plug when the need arises? In other words, on the outside of the metal box I want to have a little hole (or something, not necessarily a hole) into which the Prop Plug can be inserted easily when I need to update software, etc.
a thousand thanks,
Mark
It might be the Information Age but the Eon of Ignorance has yet to end.
a thousand thanks,
Mark
Thanks, Mike,
but I was hoping to find some kind of widget that screws/bolts to the metal enclosure so it takes all my clumsy force when having to plug and unplug the Prop Plug when needed. I then wanted to solder wires to lead from the widget to the Propeller so the Propeller itself does not have to be very close to the wall of the enclosure. Maybe those leads have to be super-short anyway??? Hmmm.... that I don't know. Anyway, I figured there were plenty of people who have ruggedized this sort of connection and I am hoping to find exact part numbers so I don't have to play guessing games with connectors. I seem to have a terrible time sifting through the mountains of connectors I see in catalogs of the sort Digikey puts out.
cheers,
Mark
Leon
Amateur radio callsign: G1HSM
Suzuki SV1000S motorcycle
But I think what I'm looking for is something with a flange, kinda like the thing seen in the photo I've attached (but with 4 positions, of course, and none of the little latchy things inside).
I don't want to have to kluge anything too much. My prototype cornered the market on kluge activity, so I'm aspiring for something a little less me.
Anybody out there with the ultimate mate for a Prop Plug? Is there a website something like eHarmony for electronic plugs???
Jason
Yes, Phil, that's correct. On the other side of the enclosure, I have a line of BNC connectors whose leads I want to be as short as possible (these are accepting pulses of about 50 ns wide). For all else (Prop connection, DS18B20 connections, etc.), I can run longer wires, I hope.
I'm surprised that it's so hard to find the plug of my dreams. I've looked through Digikey, etc. and.... perhaps JasonDorie is correct....
Jonathan
www.madlabs.info - Home of the Hydrogen Fuel Cell Robot
(Sigh) Yes, hokay.... I guess some sort of dongle thingy is the only way to go. And a phone jack sounds like a good idea. At least the adapter doesn't always have to be hanging off the box. But, knowing me, it probably will. I can almost hear the church ladies on the tour bus already: "Lawrd ha'mercy it ain't nothin but a wig of phone cords!"
Mark
http://www.molex.com/pdm_docs/sd/701070038_sd.pdf
Sticks out a bit. I'm also surprised at how hard it is to find something.
We can't talk you into a USB mini-B which has plenty of panel mounted options, with the usb-to-uart inside your box?
tubular
Post Edited (Tubular) : 1/17/2009 6:26:23 AM GMT
Well, I'm opening up to all kinds of suggestions on this. Your molex idea looks inviting, too. At least I know I'm not totally "plug-stupid" and simply couldn't find what I was first looking for. It seems that, unless you select your maie-female hookups from the beginning, retrofitting electronic connections is like looking for extra-terrestrial intelligence: you are almost positively sure it's out there somewhere but wh-wh-..... WHERE???
thanks for the help,
Mark
The one shown is the PX0446 with the nut on the outside of the enclosure.· They do others with the nut on the inside, and with PCB pins rather than a dangling cable/header.· Mouser or Newark.
tubular
