RFID code help
Maybe this is asking too much but could someone walk me through what is exactly happening with this example source code. I am still a newbie to understanding what some of this stuff means.
Or maybe there is documentation somewhere I can further study?
' File....... RFID_basic.BS2
' Purpose.... RFID Tag Reader
' Author..... (c) Parallax, Inc. -- All Rights Reserved
' E-mail..... support@parallax.com
' Started....
' Updated.... 02 Mar 2005
' {$STAMP BS2}
' {$PBASIC 2.5}
' -----[noparse][[/noparse] Program Description ]---------------------------------------------
' Reads tags from a Parallax RFID reader and displays ID to debug screen
' -----[noparse][[/noparse] Revision History ]------------------------------------------------
' -----[noparse][[/noparse] I/O Definitions ]-------------------------------------------------
Enable PIN 0 ' low = reader on
RX PIN 1 ' serial from reader
' -----[noparse][[/noparse] Constants ]-------------------------------------------------------
#SELECT $STAMP
#CASE BS2, BS2E, BS2PE
T2400 CON 396
#CASE BS2SX, BS2P
T2400 CON 1021
#CASE BS2PX
T2400 CON 1646
#ENDSELECT
Baud CON T2400
LastTag CON 3
#DEFINE __No_SPRAM = ($STAMP < BS2P) ' does module have SPRAM?
' -----[noparse][[/noparse] Variables ]-------------------------------------------------------
#IF __No_SPRAM #THEN
buf VAR Byte(10) ' RFID bytes buffer
#ELSE
Char VAR Byte ' character to test
#ENDIF
tagNum VAR Nib ' from EEPROM table
idx VAR Byte ' tag byte index
' -----[noparse][[/noparse] Initialization ]--------------------------------------------------
Reset:
HIGH Enable ' turn of RFID reader
' -----[noparse][[/noparse] Program Code ]----------------------------------------------------
Main:
LOW Enable ' activate the reader
SERIN RX, T2400, [noparse][[/noparse]WAIT($0A), STR buf\10] ' wait for hdr + ID
#ELSE
SERIN RX, T2400, [noparse][[/noparse]WAIT($0A), SPSTR 10]
#ENDIF
HIGH Enable ' deactivate reader
Display_Tag:
DEBUG "Tag Identification number is: ", CR
FOR idx = 0 TO 9 ' scan bytes in tag
DEBUG buf(idx)
#ELSE
GET idx, Char ' read char from SPRAM
DEBUG Char
#ENDIF
NEXT
DEBUG CR
PAUSE 500
GOTO main ' repeats code
All the lines beginning with ' are comments: these are for the programmers eyes, and they have absolutely no effect on code operation.
The section under I/O definitions allows you to name a pin so that other code is more easily read.
The section under constants allows you to name constants. Wherever you see LastTag in the program, you can replace it with 3 and there is no difference in execution.
The section under variables declares named variables.
The initialization turns off the RFID reader.
The Main: is a program label. Everything below that (before the next label) is a logical block of code that is "main" in some way. In this case, it receives information from the RFID reader and stores it in a ram location.
The Display_tag: program label is the logical block of code that displays the tag, in this case on your computer screen.
For more information about PBASIC, see the books "What's a microcontroller" and "PBASIC syntax and Reference Manual" available from the parallax main website for free download.
