Interfacing with an LTC1451
Ok, I am trying to interface with the LTC1451 12 bit DAC. I am using a modified version of the AD8803 code from the OBEX.
The only code that was changed was the demo code, AD8803_Demo, to cycle from values of 0 to 4096, and the AD8803.spin code, where I have replaced the bit size with 12 instead of 8. I have also removed the DACaddress variable, since the LTC1451 is a single DAC, not an octal.
Here is a copy of the Demo code, and below that is the modified AD8803.spin code:
I connected a scope to the CLK, CS, and SDI inputs, and noted that the Prop counts up to the 8th bit, then restarts the cycle. It does not go to the 12th bit.
I am wondering, since it looks as though the AD8803.spin code is independent to the bit width, why it would do this?
CON _CLKMODE = XTAL1 + PLL16X _XINFREQ = 5_000_000 CS = 3 SDI = 2 CLK = 1 OBJ DAC: "LT1451" VAR byte DACaddress,DACvalue PUB Demo | x repeat repeat x from 1 to 4096 DACvalue := x DAC.Set(CS,SDI,CLK,DACvalue) waitcnt(clkfreq/100+cnt)
PUB Set(CS,SDI,CLK,DACvalue) dira[noparse][[/noparse]CS] := 1 'Make CS pin an output dira[noparse][[/noparse]SDI] := 1 'Make SDI pin an output dira[noparse][[/noparse]CLK] := 1 'Make CLK pin an output outa[noparse][[/noparse]CS] := 0 'Bring CS low outa[noparse][[/noparse]CLK] := 0 'Bring CLK low ; load AD8803 data SendData(SDI,CLK,12,DACvalue) 'Select Value outa[noparse][[/noparse]CS] := 1 'Bring CS high ; latch AD8803 data PRI SendData(SDI,CLK,Bits,Data)|temp 'Send DATA MSB first temp := 1 << ( Bits - 1 ) repeat Bits outa[noparse][[/noparse]SDI] := (Data & temp)/temp 'Set bit value outa[noparse][[/noparse]CLK] := 1 'Clock bit outa[noparse][[/noparse]CLK] := 0 'Clock bit temp := temp / 2
You need to re-define DACvalue as a word
This section of code ...
...should read
Note: You can·remove DACaddress since you don't use it in your case.
Beau Schwabe
IC Layout Engineer
Beau Schwabe
IC Layout Engineer
I think I was more caught up in figuring out how to communicate with the DAC (I am not too good with serial communications), that I overlooked that bit!
