propeller serial output problem
I have been working with the propeller prop stick for a couple of weeks now, and cant seem to get a serial signal out of it.· Im not very experienced with microcontrollers yet, but i have tried everything to solve this problem.· i've tried several different code scenarios, using SimpleSerial, FullDuplexSerial, and the BS2Functions code from the object exhange.· i've hooked the oscilloscope to the pin, run some tests, and see no signal.· all im trying to do right now is input a gps string, and then output it to an lcd or hyperterminal to see if the propeller is recognizing the string and outputting it correctly.· in the future·i need to be able to input gps data and do some calculations.
Some help please?
Some help please?
''***************************** ''* Simple_Serial test * ''* * ''***************************** CON _clkmode = xtal1 + pll16x _xinfreq = 5_000_000 OBJ SS_test : "Simple_Serial" PUB go '' Starts 'Simple_Serial'. '' Use a terminal program on the host machine to communicate. SS_test.init(31, 30, 9600) repeat SS_test.tx("*") while trueI didn't have a board with an RS-232 driver on it, so it outputs via the Prop Tool to a comms program on the PC.
I just checked it and it definitely works. If it doesn't work for you there must be something wrong with your hardware.
Leon
Amateur radio callsign: G1HSM
Suzuki SV1000S motorcycle
Post Edited (Leon) : 1/14/2009 12:22:16 AM GMT
as a general advice. If something does not work reduce the complextity AS MUCH as possible
to narrow down the problem. (Like it is done in democode above)
As you say that you don't see any signal on a scope. For a good help you need to attach your code to a posting.
Otherwise we - the forum - are guessing into the fog: it might be this - it might be that
and it will take 10 or 20 postings to narrow down the problem.
If you attach your code. In most cases it will be done in ONE answer
best regards
Stefan
thanks!
