100 watt light bulb driver
I want to drive two light bulbs,,,alternating,,,using a 555 timer.with· either a relay or· a mosfet..How do I calculate the gate resistor value of the mosfet? Probably· a relay will be easier?· Any help
Leon
Amateur radio callsign: G1HSM
Suzuki SV1000S motorcycle
Leon
Post Edited (Leon) : 1/12/2009 6:12:10 AM GMT
If there is any doubt, and you are not trying to control the brightness of the lights, just the on and off state rather, go with a Solid State Relay (SSR).· For 100 Watts You will need at least 3 Amp... (doubling the safety rule of thumb).
If it is brightness that you want to control, then neither a simple 555 or MOSFET solution will work, you need something more sophisticated that's going to operate around the zero crossing of the AC.· BTW - many commercial SSR's have a narrow window near the zero crossing where they will turn "ON".· This ensures that they run cool by switching before the voltage peaks, but at the same time it makes them a bad candidate if you want to control brightness.
I would suggest taking a look at this document regardless of if you just want to turn the light on or off or even adjust the brightness.· It shows how to safely construct an Opto-isolated SSR without an upper turn on limit and also how to construct an Opto-isolated Zero-Cross detector to work with the SSR to control the brightness.
http://www.parallax.com/Portals/0/Downloads/docs/cols/nv/vol8/col/nv146.pdf
Beau Schwabe
IC Layout Engineer
For the opto-isolator i would recommend the moc3011
and for the triac use 2N6073a.
For a few dollars you can easily do this.
Also how does the lamps dim on jons circuit,,do you need to change the program,,to dim the lamps?
The article I provided a link for earlier tells you what you need to know. Using two Opto-isolators, one to monitor the Zero-crossing of the AC voltage, and another to control a triac driving the light. The program involved controls the timing to the triac telling it when to turn ON upon detecting each Zero-Cross. See page 3 of the link below.
Beau Schwabe
IC Layout Engineer
