Propeller Current Consumption Oddities -- and a Conclusion
Phil Pilgrim (PhiPi)
A question came up in a different thread about why Spin programs draw more current than assembly programs (according to the graphs in the datasheet). One hypothesis had it that it was because the interpreter was always busy with hub interactions. I hypothesized that because of the hub interactions (and consequent idles waiting for the hub) that Spin programs should consume less current, not more, than non-hub-interacting assembly programs. So I decided to see for myself.
The Propeller Demo Board has a handy jumper that can be removed that breaks the Vdd connection for hooking up an ammeter (or low-ohmic resistor and voltmeter). Here are the programs I tried, along with their Vdd current draw, as measured on the Demo Board:
A. Spin loop only (14.2mA)
B. Assembly loop only (10.1mA)
C. Assembly loop with RDLONG from RAM (10.1mA)
D. Assembly loop with RDLONG from ROM (10.7mA)
E. Assembly loop with RDLONG from ROM + NOP (13.4mA)
Observations so far:
····1. Assembly programs require less current than Spin programs, confirming the datasheet.
····2. It takes more current to read from RAM than from ROM.
····3. Programs that hit the hub "sweet spot" (E) require more current than programs that wait for hub access (D).
····4. Programs that hit the hub "sweet spot" (E) require more current than programs that don't access the hub (B).
Now I know Chip writes some amazingly tight code. But how can his interpreter draw more current than an assembly loop that hits the hub sweet spot every time (reading from ROM, no less)?
This required more testing. Maybe some instructions require more current than others. After all, NOPs and JMPs are pretty much "free" instructions, effortwise. So I added an ADD to the loop in B. Aha!
F. Assembly loop + ADD (15.1mA)
G. Assembly loop with RDLONG from ROM + ADD (14.3mA)
Conclusions:
Okay, now we're comparing apples with apples and can revise a couple observations:
····1. Assembly programs require less current than Spin programs, confirming the datasheet. See #5.
····4. Programs that hit the hub "sweet spot" (E) require more current than programs that don't access the hub (B). See #6.
····5. Realistic assembly programs require just as much current as Spin programs, if not more.
····6. Hub accesses decrease the average current requirements due to the waiting time (even the single-cycle wait when hitting the "sweet spot").
So there you have it. It all makes sense now, at least to me. I think the datasheet is a little misleading in this regard, since it gives the impression that Spin programs are more current-consumptive than assembly programs. But this is only because the example program (JMP only) cited is not doing any real work, whereas the Spin interpreter is. So the difference, it turns out, has little to do with hub accesses.
Post Edited (Phil Pilgrim (PhiPi)) : 1/11/2009 9:10:05 AM GMT
CON _clkmode = xtal1 + pll16x _xinfreq = 5_000_000 PUB main repeat
CON _clkmode = xtal1 + pll16x _xinfreq = 5_000_000 PUB main cognew(@loop, 0) DAT loop jmp #loop
CON
PUB main
cognew(@loop, 0)
DAT
loop rdlong x,addr
jmp #loop
addr long $1000
x res 1
CON
PUB main
cognew(@loop, 0)
DAT
loop rdlong x,addr
jmp #loop
addr long $8000
x res 1
CON
PUB main
cognew(@loop, 0)
DAT
loop rdlong x,addr
nop
jmp #loop
addr long $8000
x res 1
CON
PUB main
cognew(@loop, 0)
'cognew(@loop, 0)
DAT
loop add x,#0
jmp #loop
addr long $8000
x res 1
CON
PUB main
cognew(@loop, 0)
'cognew(@loop, 0)
DAT
loop rdlong x,addr
add x,#0
jmp #loop
addr long $8000
x res 1
Conclusions:
Are you up to testing current consumption of instructions other than ADD whilst your at it? Or ADD/SUB with different operand values. Just curious.
Post Edited (heater) : 1/11/2009 8:55:02 AM GMT
Maybe, if I have time tomorrow, I could test some other instructions. The main discrepancy that was bugging me has been resolved, though, so I may just leave it and move on.
Now, in hindsight, I guess I am not surprised.
Prop Tools under Development or Completed (Index)
http://forums.parallax.com/showthread.php?p=753439
My cruising website http://www.bluemagic.biz
I asked this question in the forum, when the first datasheet was released, but got no answer.
I must say that the Assembly current consumption curve in the datasheet has no relevance, in this case !
Andy
John
'Necessity is the mother of invention'
Those who can, do.Those who can’t, teach.
I think people are expecting too much from the datasheet, as Phil's experiments have shown measuring current consumption is a very dependent activity. You will get different results depending on what you do, and this isn't even taking into account I/O with varying impedance loads. The datasheet only attempts to provide a generalized picture of current consumption through a few select cases.
In order to arrive at the level of detail where all mysteries are resolved would require calculating how many coulombs each and every instruction would take (with hub accesses having many entries depending on how many clock cycles were used). But who would really use this information (who's use·would require computing a summation series hundreds of entries long then divide by execution time) when all you have to do is Phil's real world measurement of the system in action?
BTW nice job Phil.
Paul Baker
Post Edited (Paul Baker) : 1/11/2009 9:02:07 PM GMT
Tracy Allen
www.emesystems.com
Paul Baker
It would be hard to measure instruction-by-instruction current variations without removing all the bypass caps. Even then, any residual inductance would tend to blur the demarcations between instructions.
It looks like the determinant factor for invoking the ALU gets complicated by the conditionals. Here are some example code fragments:
H. Loop with NOP (11.8mA)
loop nop jmp #loopI. Loop with ADD zero (15.5mA)
loop add x,#0 jmp #loopJ. Loop with ADD one (15.7 - 16.1mA)
loop add x,#1 jmp #loopK. Loop with ADD zero not performed (14.0mA)
loop if_never add x,#0 jmp #loopL. Loop with ADD #1 not performed (14.4mA)
loop if_never add x,#1 jmp #loopM. Loop with ADD #511 not performed (15.6mA)
loop if_never add x,#511 jmp #loopN. Loop with ADD $8000_0000 (15.9mA)
loop add x,adder 'adder is long $8000_0000 jmp #loopO. Loop with ADD $8000_0000 not performed (14.2mA)
loop if_never add x,adder 'adder long $8000_0000 jmp #loopP. Loop with ADD $8000_0000 nr (14.4mA)
loop add x,adder nr 'adder long $8000_0000 jmp #loopQ. Loop with ADD $8000_0000 not performed and nr (14.mA)
loop if_never add x,adder nr 'adder long $8000_0000 jmp #loopConclusions:
····7. There's more happening when a conditional is not met than just substituting a NOP. (Strictly speaking any instruction with if_never is a NOP. But the assembler inserts one with low current consumption.) My guess is that the instruction is performed, but with writes to the result, flags, and program counter blocked.
····8. Current consumption is dependent on the number of ones in the instruction's source field.
····9. Current consumption varies with the instruction's result value.
In general, it looks like determining the average current consumption of a given program to any degree of precision a priori would be an exercise in frustration.
Post Edited (Phil Pilgrim (PhiPi)) : 1/12/2009 3:09:58 AM GMT
I am playing with an FPGA doing a Cog emulation and in the 2nd cycle I have decoded the cccc and c & z flags to determine if the instruction will be executed. If not, then this translates into a nop. From your tests (as you state), it implies that the prop performs the operation and prevents the update.
Chip: good idea to save current on the propII (if you haven't already). I've also worked out (in theory) how to have no penalty cycles in non-taken jumps.
