Some help required.
Hello, I am using the Prop for a robotics platform and I would like to feedback the current battery voltage (leftover) to another computer but I do not have any idea on how to mesure the battery voltage using the prop.· if somebody would like to put me on the right direction?· Thanks a lot.
jm.
jm.
Leon
Amateur radio callsign: G1HSM
Suzuki SV1000S motorcycle
jm
**Edited
You could probably get away with using some diodes to measure the voltage. Wire them up as a switch and limit the current into the propeller.
***Edited again
Just thought of a great simple idea:
Using a Varicap diode one could measure battery voltage if configured as a RC Circuit. I think there already is a RC measuring object. Since the Varicap diodes capacitance changes with respect to voltage then this could work. This is a theory however, but seems possible.
Post Edited (grasshopper) : 1/10/2009 11:30:44 PM GMT
Leon
Many ADCs have internal references that use Vdd to generate it, since you have a regulator putting out a stable voltage everything will work.
Paul Baker
Cheers!
Paul Rowntree
Attached is a schematic, and here is a Spin code: (only the ADC methode, and not tested)
CON batt = 7 'I/O Pin for Battery ADC PUB getBatt : time dira[noparse][[/noparse]batt] := 1 'discharge C outa[noparse][[/noparse]batt] := 0 time := 0 dira[noparse][[/noparse]batt] := 0 'Pin to input repeat time++ 'measure time until ina[noparse][[/noparse]batt] > 0 'until C > 1.4V threshold dira[noparse][[/noparse]batt] := 1You get not a value in Volt, but a value which is higher for low Battery voltage, and lower for higher Battery voltage.
(because the C is charged faster if the current is higher, and the current is higher if the battery voltage is higher).
Andy
