Help with 74HC595 8-bit shift register with latch.
mynet43
I'm trying to help someone on the forum drive this chip from a prop.
The problem is that they have the chip and I don't have one to test with.
They're a relative newby to the prop so I wrote the following driver.
They're using it to drive a set of 8 LED's.
Apparently it almost works. It latches the values for about a second and then
drops the lights and bit 0 flickers, as best as I can understand the description from long distance.
Here's the driver code I wrote. Would someone please take a look at it and let me know if you
spot something? If you have a chip to debug it (or a working driver), that would be even better[noparse]:)[/noparse]
Thanks for your help.
Jim
Jim
'' * "HC595.spin" 74HC595 SPIN Object *
'' * coded by Jim -- 12/31/08 -- Happy New Year! *
'' * Version 1.0 *
'' Calling sequence
'' OBJ
'' SReg : "HC595"
'' code segment
'' SReg.InitSer595 ' to initialize driver
'' more code
'' DataByte := toSend ' set up data to send to chip
'' SReg.WriteSer595(DataByte) ' send data to chip
'' more code
CON
_PinHigh = 1
_PinLow = 0
CLK = 0 ' pin number of CLK pin on chip (AKA SCK)
SER = 1 ' pin number of SER pin on chip
CLR = 2 ' pin number of SCLR pin on chip
RCK = 3 ' pin number of RCK pin on chip
GPN = 4 ' pin number of G pin on chip
VAR
long bitout, databyte
PUB InitSer595 ' initialize 74HC595 for startup
' set the control lines as outputs
dira[noparse][[/noparse]CLK] ~~
dira[noparse][[/noparse]SER] ~~
dira[noparse][[/noparse]CLR] ~~
dira[noparse][[/noparse]RCK] ~~
dira[noparse][[/noparse]GPN] ~~
outa[noparse][[/noparse]CLK] := _PinLow ' init main clock line to low
outa[noparse][[/noparse]RCK] := _PinLow ' init latch clock line to low
outa[noparse][[/noparse]GPN] := _PinHigh ' set outputs to 3-state
outa[noparse][[/noparse]CLR] := _PinLow ' set to clear register on chip
outa[noparse][[/noparse]GPN] := _PinLow ' turn on the chip and clear pins
outa[noparse][[/noparse]CLR] := _PinHigh ' return CLR pin to high after clear
PUB WriteSer595(Data) ' Data is long with 8 bits of data in bits 7 - 0
' Write 8 bits of data. Data byte is output MSB first.
databyte := Data ' transfer to working storage
repeat 8 ' shift out 8 bits
bitout := databyte & %1000_0000 ' take hi bit from byte -> bitout bit 7
bitout >>= 7 ' shift to bit zero for output
databyte <<= 1 ' shift data left 1 bit for next loop
outa[noparse][[/noparse]SER] := bitout ' shift out high bit to serial pin (0 or 1)
outa[noparse][[/noparse]CLK] := _PinHigh ' toggle the clock pin to shift bit out
outa[noparse][[/noparse]CLK] := _PinLow ' high then low to cycle the clock
outa[noparse][[/noparse]RCK] := _PinHigh ' toggle the RCK pin to latch the output
outa[noparse][[/noparse]RCK] := _PinLow ' high then low to cycle the clock
No need to have a databyte variable, just work straight off the input parameter
No need to have a bitout variable either, just use the data parameter (lsb)
The problem sounds more like a hardware problem, a poor supply, no decoupling, glitch on the clock or something like that.
*Peter*
*Peter*
'' ****************************************************************************** '' * "HC595.spin" 74HC595 SPIN Object * '' * coded by Jim -- 12/31/08 -- Happy New Year! * '' * Version 1.0 * '' ****************************************************************************** '' '' Calling sequence '' OBJ '' SReg : "HC595" '' '' code segment '' SReg.InitSer595 ' to initialize driver '' more code '' DataByte := toSend ' set up data to send to chip '' SReg.WriteSer595(DataByte) ' send data to chip '' more code '' CON _PinHigh = 1 _PinLow = 0 CLK = 0 ' pin number of CLK pin on chip (AKA SCK) SER = 1 ' pin number of SER pin on chip CLR = 2 ' pin number of SCLR pin on chip RCK = 3 ' pin number of RCK pin on chip GPN = 4 ' pin number of G pin on chip PUB InitSer595 ' initialize 74HC595 for startup ' set output register before pin becomes an output (avoids glitches) outa[noparse][[/noparse]GPN] := _PinHigh ' set outputs to 3-state outa[noparse][[/noparse]CLR] := _PinLow ' set to clear register on chip outa[noparse][[/noparse]RCK] := _PinLow ' init latch clock line to low outa[noparse][[/noparse]CLK] := _PinLow ' init main clock line to low ' set the control lines as outputs dira[noparse][[/noparse]CLK] ~~ dira[noparse][[/noparse]SER] ~~ dira[noparse][[/noparse]CLR] ~~ dira[noparse][[/noparse]RCK] ~~ dira[noparse][[/noparse]GPN] ~~ outa[noparse][[/noparse]GPN]~ ' turn on the chip and clear pins outa[noparse][[/noparse]CLR]~~ ' return CLR pin to high after clear PUB WriteSer595(Data) ' Data is long with 8 bits of data in bits 7 - 0 ' Write 8 bits of data. Data byte is output MSB first. Data ><= 8 ' bitwise reverse the lsbs repeat 8 ' shift out 8 bits outa[noparse][[/noparse]SER] := Data ' shift out next bit (bit0) to serial pin (0 or 1) outa[noparse][[/noparse]CLK] ~~ ' toggle the clock pin to shift bit out outa[noparse][[/noparse]CLK] ~ ' high then low to cycle the clock Data >>= 1 'next bit outa[noparse][[/noparse]RCK]~~ ' toggle the RCK pin to latch the output outa[noparse][[/noparse]RCK]~ ' high then low to cycle the clockP.S. just edited the code again to use the shortform bitset operators ~~ and ~
I wrote the thing in about 15 minutes, too lazy to look up a couple of things[noparse]:)[/noparse]
It looks like you were right the first time, hardware problem...
Either that or we were clocking the signals out too fast for the chip.
It seems to be working now.
Thanks for looking at it.
Jim
outa[noparse][[/noparse]CLK] ~~ ' toggle the clock pin to shift bit out outa[noparse][[/noparse]CLK] ~ ' high then low to cycle the clockI'm not sure how many clock cycles the outa[noparse][[/noparse] ] instruction takes.
take a look into the datasheet the minimum pulsewidth depends on the supply-voltage longest pulsewidth at 2V
a little less than 0.1 microseconds on higher voltages even faster.
I have coded a 595 in assembler with almost no delays and it is working
so coded in SPIN the pulsewidth is far long enough for proper switching
again in the datasheet you can see that the clocks are triggered on the LOW-HIGH-transistion
you code does it the opposite way HIGH-LOW so as a quick guess the flickering of LED 0 is because
bit 0 is shifted/latched if the NEXT cycle begins
So the toogling of the clocks has to vice versa
' toggle the clock pin to shift bit out outa[noparse][[/noparse]CLK] ~ 'set Pin LOW to prepare transition outa[noparse][[/noparse]CLK] ~~ 'pin HIGH: the LOW-HIGH-transition triggers the clockbest regards
Stefan
@stefanl38: The toggling that mynet does changes the data bit then it takes the clock high (from previous low) and then low again. But since the clock is low-to-high sensitive it doesn't matter whether it is low then high-low or high then low-high.
*Peter*
Leon
Amateur radio callsign: G1HSM
Suzuki SV1000S motorcycle
Leon
Thanks everyone for the great responses, they really help.
I'm going to have to go back and read the thread again. There was a question about the direction of my clock transitions.
I first set the data line and then set the clock high. This should cause a low to high transition, which I'm pretty sure is right. Let me know if I missed something.
I'm glad to hear that someone coded it in assembly. That makes me think the code should work.
Remember, I'm doing this long distance, I'm in CA and he's in PA (with the HC595). I'll have him check for caps and to make sure the lines aren't too long.
Thanks again for the great feedback!
Jim
Leon
pin 9 of the 595 is the serial data OUTput called Qh
you simply connect Qh of 595 no 1 with serial data INput of 595 no 2, etc, etc, etc
shiftclock and latch are parallel
you trigger the latch ONLY at the end of shifting ALL 32, 48, or whatever amount of bits
that's all
best regards
Stefan
Post Edited (StefanL38) : 1/8/2009 3:52:01 PM GMT
This is mynets code and I can get to work with one chip. I do not see the clk~~, clk~ code to modify as in your earlier post.
I tried what you said with the qh to serial in of #2 but nothing. Here is the code I have working for 1 chip.
Don
Don
