school project idea needs help
ok, i have to give a demonstration speech at school, and i thought an ion lifter would be really cool, my first question is, is an ion lifter a good topic, or is there another one you guys you can think of that would incorporate the prop with, my second question is, if i were to pulse a transistor on and off with the prop at a very high speed and then hook a transformer up to it, and then a second tranformer hooked up to that and so on till i got·a high enough volts
Regardless, cool project!
PG
Just pulsing a pin to build a large charge seems like a waste of a prop.... unless it's doing other things as well.
Class project ideas using the prop that come to mind:
1. Servo bot similar to BOE (but able to process multiple "stimuli" at once)
2. Coil gun (though still no need for so much smarts)
3. Audio Oscilloscope
4. Game and/or Game System (think Hydra)
great effects with the sugestions above.
If somebody get hurt by that you are in really big trouble
I have a complete different idea
I call it "walking a function"
This means there is a carpet 1x5 meters long. It has marks at every meter. At the 0m-end there is a monitor placed on a pillar showing a text start at X meters. Then a countdown of 10 seconds.
and then you see a X-Y-diagram and a function is drawed with f.e. color yellow into the X-Y-diagram
and a white cursor starts moving forward the person should walk forward and backward
to adjust the Y-value in that way that the white cursor fits the yellow line.
The software measures the distance of the person from the monitor with an ultrasonic sensor
and draws a white line according to the distance
By this way the person "walks" the function. A new experience what it means if the Y-value of a function y := f(x) goes up and down with X-value
or the y-value stays the same for 1 < X < 3 or what ever
I saw this in a mathematical museum.
The TV or VGA-Output of the propeller should be good enough to show this on a screen
So this would even be didactic and I think your teacher would like it
best regards
Stefan
i plan on showing how to build one out of several cameras, quick question though, is there any solution to getting it to fire from the prop, like an scr(it think thats what there called) and im going to at the end pull out a turret and mount the barrel to it
as soon as the ball has advanced.
Use as high a voltage as you feel safe with
(maybe 30V) on the coils, and to allow a fast decay, a zener clamp rather than a
clamp diode. Plenty of energy storage cap will be needed, as this will draw amps.
Sensing the location of the ball will be interesting [noparse]:)[/noparse]
I see Slot Opto interrupter devices come up to 8mm wide ?
Fire at a target or perhaps make a nut-cracker ?
Add a large power resistor to fire supply, before the storage caps, to give some
safety should things stay on longer than you intend ! [noparse]:)[/noparse]
actually i really like the nut cracker idea, maybe i will work on seeing if that will work
Power MOSFETS are easier to get, and work better.
You could fry-protect the prop, with a series gate resistor, and a clamp Zener.
Usually tho, a low milli-ohm mosfet will just sag the supply.
I would start with a current limited supply (not a car battery....)
Cameras could be tricky to interface to, and have a shutter and scan delay, plus
will find it hard to see the ball inside the coils.. ?
Put a LED on the coils, so everyone can see them fire. LEDs are visible, even with
very short current pulses.
A display of ball speed on exit could be good too ...
Nuts and Volts Vol 29 No 3
March 2008
http://www.nutsvolts.com/index.php?/magazine/issue/2008/03
Just might help you not wake up on the floor drooling... But my CDI igniton has done it to me a few times now... Good Luck
TJ
