Serial Output - Help
********NEED SOME HELP PLEASE *****
The program below displays two ADC channels on a TV screen,but I·want to·send the two readings out P3 on Propeller demo board via serial communication for remote display. I added the lines in red below but I do not get intelligible data out the serial port to an LCD display. I can read gibberish but cannot even read string text?·Where did I go wrong?·· HELP
··· Test LTC1298 Demo
··· Charlie Dixon (CDSystems) 2007
CON
· _CLKMODE = XTAL1 + PLL16X
· _XINFREQ = 5_000_000
· _stack = ($3000 + $3000 + 100) >> 2·················· 'accommodate display memory and stack
· x_tiles = 16
· y_tiles = 12
· x_screen = x_tiles << 4
· y_screen = y_tiles << 4
· width = 0············ '0 = minimum
· x_scale = 1·········· '1 = minimum
· y_scale = 1·········· '1 = minimum
· x_spacing = 6········ '6 = normal
· y_spacing = 13······· '13 = normal
· x_chr = x_scale * x_spacing
· y_chr = y_scale * y_spacing
· y_offset = y_spacing / 6 + y_chr - 1
· x_limit = x_screen / (x_scale * x_spacing)
· y_limit = y_screen / (y_scale * y_spacing)
· y_max = y_limit - 1
· y_screen_bytes = y_screen << 2
· y_scroll = y_chr << 2
· y_scroll_longs = y_chr * y_max
· y_clear = y_scroll_longs << 2
· y_clear_longs = y_screen - y_scroll_longs
· paramcount = 14
· display_base = $5000
· bitmap_base = $2000
VAR
··· long· tv_status···· '0/1/2 = off/visible/invisible·········· read-only
··· long· tv_enable···· '0/? = off/on··························· write-only
··· long· tv_pins······ '%ppmmm = pins·························· write-only
··· long· tv_mode······ '%ccinp = chroma,interlace,ntsc/pal,swap write-only
··· long· tv_screen···· 'pointer to screen (words)·············· write-only
··· long· tv_colors···· 'pointer to colors (longs)·············· write-only··············
··· long· tv_hc········ 'horizontal cells······················· write-only
··· long· tv_vc········ 'vertical cells························· write-only
··· long· tv_hx········ 'horizontal cell expansion·············· write-only
··· long· tv_vx········ 'vertical cell expansion················ write-only
··· long· tv_ho········ 'horizontal offset······················ write-only
··· long· tv_vo········ 'vertical offset························ write-only
··· long· tv_broadcast· 'broadcast frequency (Hz)··············· write-only
··· long· tv_auralcog·· 'aural fm cog··························· write-only
··· word· screen[noparse][[/noparse]x_tiles * y_tiles]
··· long· colors[noparse][[/noparse]64]
··· long· x, y, cel, far····
OBJ
··· tv··· :···· "TV"
··· gr··· :···· "CD_Graphics"
··· Num·· :···· "CD_Numbers"
··· adc·· :···· "CD_LTC1298"
··· SER·· :···· "FullDuplexSerial"···
PUB MAIN | i,dx,dy,Temp
ser start(4,3,0,2400)
··· 'start tv
··· longmove(@tv_status, @tvparams, paramcount)
··· tv_screen := @screen
··· tv_colors := @colors
··· tv.start(@tv_status)
··· 'init colors
··· repeat i from 0 to 63
····· colors[noparse][[/noparse]i] := $00001010 * (9) & $F + $2B060C02·· '$00001010 * (5+4) & $F + $2B060C02
··· 'init tile screen
··· repeat dx from 0 to tv_hc - 1
····· repeat dy from 0 to tv_vc - 1
······· screen[noparse][[/noparse]dy * tv_hc + dx] := display_base >> 6 + dy + dx * tv_vc + ((dy & $3F) << 10)
·· 'start and setup graphics, LTC1298 ADC chip
··· gr.start··········································· 'Start Graphics Driver
··· gr.setup(16, 12, 128, 96, bitmap_base)
··· adc.start(0)······································· 'Initialize ADC chip
' Main Program Loop to get and display ADC data to TV Screen
··· repeat
····· dira[noparse][[/noparse]3] ~~
····· gr.clear······································· 'Num.ToStr(Temp, Num#DEC)
····· gr.colorwidth(1, 2)···························· 'Resolution = 5.00V / 4096 = 0.00122
····· gr.textmode(1,1,7,%0000)························
····· Temp := adc.GetADC(0) * 5000/4096·························
····· gr.text(-128,65,string("ADC Channel 0: ","··· mV"))
····· gr.text(-25,65,Num.ToStr(Temp, Num#DEC))
····· Temp := adc.GetADC(1)· * 5000/4096
····· gr.text(-128,35,string("ADC Channel 1: ","··· mV"))
····· gr.text(-25,35,Num.ToStr(Temp, Num#DEC))
····· gr.copy(display_base)
····· ser.tx(10)
····· ser.tx(13)
····· waitcnt (500_000 * 50 + cnt)
····· ser.str (string ("ADC Channel 0: ","··· mV"))
····· ser.dec·(Temp)
····· ser.tx (10)
····· ser.tx (13)
····· ser.str (string ("ADC Channel 1: ","··· mV"))
····· ser.dec (Temp)
····· ser.tx (10)
····· ser.tx(13)
DAT
Zero··················· word··· $30
DP····················· word··· $2E
Hyphen················· word··· $2D
tvparams··············· long··· 0·············· 'status
······················· long··· 1·············· 'enable
······················· long··· %001_0101······ 'pins
······················· long··· %0000·········· 'mode
······················· long··· 0·············· 'screen
······················· long··· 0·············· 'colors
······················· long··· x_tiles········ 'hc
······················· long··· y_tiles········ 'vc
······················· long··· 10············· 'hx
······················· long··· 1·············· 'vx
······················· long··· 0·············· 'ho
······················· long··· 0·············· 'vo
······················· long··· 0·············· 'broadcast
······················· long··· 0·············· 'auralcog
color_schemes·········· long··· $BC_6C_05_02
······················· long··· $0E_0D_0C_0A
······················· long··· $6E_6D_6C_6A
······················· long··· $BE_BD_BC_BA
DAT
···· {<end of object code>}
CON
· x_tiles = 16
· y_tiles = 12
· paramcount = 14
VAR
OBJ
··· 'start tv
··· 'init colors
··· repeat
····· ser.tx(10)
····· ser.tx(13)
····· ser.tx (10)
····· ser.tx (13)
····· ser.tx (10)
····· ser.tx(13)
DAT
DAT
*Peter*
the commands seem to be OK.
What kind of display is this ?
LCD? PC terminalsoftware ?
the commands
ser.tx (10)
ser.tx(13)
let me guess it is a PC-terminalsoftware
LCDs usually don't react on linefeed carriage return
it even might be that these values are used for other purposes like changing baudrate or whatever
Is it a 5V device ? Then you have to use a 1kOhm resistor between Prop-IO-PIN and the device
does the device have a baudrate of 2400 ?
Not long ago there was a thread for a LCD where some initial commands has to be send to the LCD for proper operation
so the forum needs to know the type of device and a datasheet of this device
Maybe you have to use one of the inverted modes or pull-up-resistors
or a voltage-levelshifter to 5V or true RS232-levels
how should we know that without knowing details about the device ?
best regards
Stefan
Also
For test purposes, I am using an ILM-216 LCD display to display the program data at 2400 baud.
Looking at the --- ser start(4,3,0,2400) command, How do I know if I set the MODE correctly, where can I get more info on mode settings for serial.
thanks for any and all help
Tom
Your mode should be 0 unless the lcd is expecting RS232 data and you are connecting straight from the Prop's I/O in which you will need to invert the signals by setting mode to 3 which inverts the rx and tx. For more info simply look at the comments that are embedded in the serial object.
*Peter*
I'am almost there but not quite!!!
thanks
Tom
You say LCD display, is this a two way or 1 way display? You might be doing an overkill using FD serial if it is a one way LCD display.
As for your last post, you read the value into temp, and overwrite it before you print it.
A simple fix is to use two different variable names, it will make you life simpler, but if you need to do it this way.
You see what is going on, you are writing over the value of Temp before you update your LCD screen, the tv one works because it updates the graphics palette, but doesn't update the screen until GR.copy is called.
Hope this helps.
TJ
I think I see what you are trying to say about overwriting the value of (Temp).
BUT ... I inserted the "simple fix" main program loop section above -- into the program but now NOTHING displays on the TV or LCD?
What are we missing here!
Tom
Disregard the last post !!!!
I re-entered the code section and it works fine.
thanks so much for your help
Tom
