electric vehicle for science olympiad — Parallax Forums
science_geekscience_geek Posts: 247
edited 2009-01-07 17:35 in General Discussion
i am building an electric vehicle for a science olympiad meet, the only thing it has to do is travel between 5 and 10 meters in an estimated time that cannot exceed 45 seconds, which is a problem for me, i planned on using parallax's continuous rotation servos, they work great for anything less then about 8 meters, the meet i had last year i used them and i ended up exceeding 45 seconds over a 9.5 meter distance, i was wondering if there was anyway to crank up the speed on the servos to about 1.5 - 2 times faster than usual speed, if its not possible is there another brand of servo i could modify for continuous rotation that i could get for cheapish
  • DufferDuffer Posts: 374
    edited 2009-01-06 22:36
    Larger diameter wheels.
    Duffer
  • PhilldapillPhilldapill Posts: 1,283
    edited 2009-01-06 23:15
    Duffer is right. Larger diameter wheels, gearing the servos up, or anything that increases the tangential velocity of the wheel itself.
  • FlyingFishFingerFlyingFishFinger Posts: 461
    edited 2009-01-06 23:55
    Make the wheels as big as possible such that at that size of wheel, you have just enough torque to move your platform. If that's not enough, I think you might need faster motors.
    Also, I've found from robotics competitions that you can increase the pulse width on servos a little over the spec value, resulting in faster rotations.
    You've got to play the game.
    You can't win.
    You can't break even, except on a very cold day.
    It doesn't get that cold.
    ~Laws of Thermodynamics~
  • science_geekscience_geek Posts: 247
    edited 2009-01-07 00:15
    thanks, i figured the bigger wheels, but i never thought of making a second "external" gearbox, ill have to try that,
    PS: i flew my rc helicopter for the first time today and i didnt crash, can you say nerve racking
  • SRLMSRLM Posts: 5,045
    edited 2009-01-07 01:39
    You can make the servo turn faster by using a higher voltage, but at the cost of a shorter life (for the servo).
  • LawsonLawson Posts: 870
    edited 2009-01-07 04:52
    On many newer servos the driver for the motor is a separate chip. In this case it's possible to "liberate" the power pin of the motor drive chip and connect it to an independent external power supply of higher voltage. I've seen this done a couple of times on BattleBot forums. (aka long lifetime wasn't a design requirement :P )
    Marty
    Lunch cures all problems! have you had lunch?
  • Cole LoganCole Logan Posts: 196
    edited 2009-01-07 16:59
    I know you said that you want to stay with the servos but one thing that I have found that works really good is electric drill motors. There fast and torque. and the useally have a chuck buit on them so its easy to add your wheel to it.
    science_geek,
    Check out my reply to this thread....
    http://forums.parallax.com/showthread.php?p=525689
    Beau Schwabe
    IC Layout Engineer
