Getting started
I need to get the boebot moving forward.
I also want it to turn around when it hits a wall.
Can someone help me? What Command should i use? and how should i set up the wiring?
I'm new to this.. don't know anything about programming.......
Please Help....
Please Help....
http://tech.groups.yahoo.com/group/JavelinCode/files/Javelin%20Stamp%20IDE/lib/JBot/
Unzip and·read the chapters.
BasicWheelServo.java is probably the class you need.
If you don't know anything about programming, start by reading
the javelin manual and do some of the tests from that manual
before moving on to the boebot.
regards peter
I'll see what i can do...
Yeah i've tried that, the problem is i need the boe bot to do this in a week.
Regards
J
