Serial Comms Between Propeller and SX
This has been hammer in these forums before but I need to understand why this doesn't work
Propeller Code
SX Code
I can't seem to get this to work... Why doesn't the SX read the "!" Will the SX read serial data from the propeller seeing as the propeller's voltage is lower that the SX?
This is the full code.
Eric
Post Edited (SailerMan) : 1/6/2009 3:58:57 AM GMT
Propeller Code
Con
_clkmode = xtal1 + pll16x
_xinfreq = 5_000_000
Var
OBJ
Serial :"FullDuplexSerial"
Pub Main | Index
Serial.Start(0,1,%0100,2400)
Repeat
Serial.STR(String("!"))
WaitCnt (Cnt+10_000_000)
SX Code
DEVICE SX28, OSCHS3
FREQ 50_000_000
ID "Serial Input"
' IO Pins
SerialIn Pin RA.1 Input ' LED pin
AlarmLED Var RA.0
ErrorLED Var RA.2
Temp Var Byte
Baud Con "T2400"
PROGRAM Start
Start:
DO
Serin SerialIn,Baud,Temp,50,Flash
If Temp="!" Then
Toggle AlarmLed
Endif
LOOP
Flash:
Toggle ErrorLED
Goto Start
Eric
Here is a scope view of the Propeller Serial Out
Post Edited (SailerMan) : 1/6/2009 4:19:33 AM GMT
