The future of servos?
Phil Pilgrim (PhiPi)
Check out these Futaba "robotic" servos:
····http://forums.parallaxinc.com/www.rc.futaba.co.jp/hobby_en/04_robot/accessory.html
····www.rc.futaba.co.jp/hobby_en/04_robot/manual/RS601CR_manual_Ver116.pdf
I haven't seen any prices or dealers for them stateside, though. [noparse][[/noparse]drool]
robots into something similar to HONDA's ASIMO. If the price drops to
competitive levels, we'll see some amazing sized humanoids or very big
Penguins.
humanoido
That explains the gargantuan torque values. At 21kg thats .85hp (different units, I converted from SI). I converted 21kg to ft/lb (not sure if that's valid, but it comes out to approximately 37 ft/lbs). I then used the formula hp = 2xPIxrpmxtorque and divided by 33000 (a constant for non-metric horsepower conversion). I calculated rpm by taking .17s / 60 degrees which ends up approximately 120rpm. That yields almost one horsepower per servo. I have .33cc engines I use for model aircraft with less power output than that - and those are internal combustion engines. There are some powerful electric motors in these guys.
John Abshier
To make something work one must build, test, and verify bfore proceding.· -- myself
