How Do I filter out This 52 kHz fixed frequency internal oscillator on a LM257
Dose any one have any idea how i should filter out this noise
I want to use this in a Project using a Basic Stamp
I have use this switching regulator before with a Basic Stamp and LCD Display but there was only a 120 millamp
on the switching regulator
This did not cause any problem for me but will loading down the regulator to more Than
·One amp or more through this switching regulator will this cause me any problem
Is this 52 kHz· noise that Switching Regulator is making while under a load ·going to make the Basic Stamp·reset it self
I took some reading with my meter and there is 52 kHz· noise· when it is under load
··Thanks for any·
·that you may have and all of your time finding them
Sam
··Thanks for any·
·that you may have and all of your time finding them·
Sam
Maybe it's your construction technique?· Did you use ground-plane or single-point technique with short-lengths·as they advise and emphasize or are the ground wires a bunch of point-to-point and so on?· That's very important.· How about a picture of it?·
Thank for your reply
I tied all the ground together as much as possible and used one very short wire between the two caps
all part the leads are as short as possible
Unless I just have to have a board made to do this project
I will try to take a photo of the board tomorrow
··Thanks for any·
Sam
*Peter*
P.S. I have attached a diagram of the switching waveform.
Post Edited (Peter Jakacki) : 1/4/2009 3:41:16 AM GMT
Thank You for point this out that was what it was it
I had to make a soilder brige to all the grounds together
and that fix the problem
This was the frist time that I made my own switching regulator board
I have seen this before using a ground plane but I did not understand why you need to
use one
Now I understand why·····
Thanks agian· ·
··Thanks for any·
Sam
·I use a higher frequency switcher
Thank You for your reply
Do you have a part # of one that you use and a web link to·the Data Sheet
··Thanks for any·
Sam
Layout is simple but I always have a ground plane. Make sure though that the ground current flows through the power-supply section if you know what I mean. The switching regulator must be the source for the regulated supply and ground, not just a stop along the way or worse still, the destination.
That is, don't have the input ground passing through all your circuitry first and then to the regulator but arrange the pcb so that the regulator is first inline with the input ground, layout is everything. (I think I said that right)
*Peter*
Do you have a lay out that·I could look at LM2675 that you have used before and that works
Thank you for all of your help in this matter
··Thanks for any·
Sam
