propstick/usb V-bat input??
Hey guys quick question I have been doing some interfacing on my propstick and it hit me these are 3.3V devices right? I have been using VDD out pin 32 of the· prop stick for my 3.3 volts but I am using 9 volts on Vin pin 12 so my question is , is there a voltage regulator built into the propstick device I also have a few prop 40 pin chips that I almost hooked up the same way so on a 40 pin prop chip is Vin have to be regulated down to 3.3 V thanks
and one more on my propsticks I have been using pullup resistors 1-10K to +5 volts on the input pins is that ok or am I over driving this thing?· example 5V
1K-resistor
LED
prop-pin of course one side of the led is going to ground just cant draw it
1K-resistor
LED
If you use the 5V with an LED, you should be OK. The LED is probably going to drop around 1.6V (give or take), so this brings the actual voltage to 3.4V, well within limits. The limiting resistor is a must, however, to limit the current. With a 1K resistor, I think you should be just fine. If the LED doesn't drop enough voltage, then it may still appear "on", although dim. This is because when the output goes HIGH, you have 5V as the supply, a drop across the resistor, and a drop across the LED, then down to 3.3V from the prop. Let's say your LED only drops 1.3V, then that means there is 0.4V across the resistor(5-1.3-3.3 = 0.4). If you are using a 1k resistor, then that is 400uA of current, enough to just barely turn the LED on.
Like I said, it would damage the chip, but it's not a good way of doing it.
Parallax's documentation clearly shows the regulator that's used (LM2937) and their webstore has the datasheet for the regulator. The amount of current available is at most 400mA and depends on the heat produced. This depends on the input voltage. Best to run it from a 5V supply, 6V maximum.
