TV Composite DAC Values
Straight to the point - How important are the DAC Resistor values for the composite TV output? I don't have any "normal" resistor values on hand, so the closest multiples I could find are 124, 301, and 680. I'm getting a gray screen whenever I try my TV output on my board... Could these values be why? I know that ideally, the resistors would be multiples of each other... 270, 560, and 1.1k seem to be the most common as these are the closest values to 150 when in parallel. Any info would be great.
Phildapill, you could add a load resistor to drop the output voltage as Mike mentioned that the load is normally 75 Ohms as part of a voltage divider so you could add another 75R to 100R from the signal to ground.
That should work.
*Peter*
1. The resistance ratio should be 1:2:4.
2. The peak-to-peak output voltage into a 75-ohm load should be 1.0 V.
3. The source impedance of the signal should be 75 ohms.
#1 and #2 are a minimum requirement. Constraint #3 should be observed for longer cable lengths. The circuits that I've presented here satisfy #1, #2, and #3. The standard Parallax circuit satisfies #1 and #2. Your values make a faint acknowledgement of #1 and actually meet #3 (78 ohms) but provide a peak-to-peak voltage of 1.65V, so miss constraint #2 by a lot. You can try combining the resistors you have on hand in various series and parallel combinations to get closer to meeting #1 and #2.
Post Edited (Phil Pilgrim (PhiPi)) : 1/3/2009 6:14:01 AM GMT
Oh, and by the way, Phil, I'm using your improved windowed TV_text. Just wanted to thank you again for the flicker free screen! [noparse]:)[/noparse]
