help to understand "memory" ?!?!?!
Hello everyone.....I have been browsing this web site for months...I am now looking fo a memory chip to implement a kind of video driver for a specific display I have. It requires at least 64KByte. For many reasons I prefer not to use the "tiles" technique of existing video driver since my Prop would need its memory for other processes...
In order to understand what you guys are doing, I have been reading this forum for a long time.
I could see that many of you are using different types of memory (flash, eeprom etc...) but they all have one problem in common...100.000 read/write cycles limit.
I understand that the·chip would be rated at least 100.000 cycles but...do you think it is reliable? do you find that number enough for your application? I wouldn't use it for a video support since I would quicly reach such number of write/read operations....
I cannot believe you guys use such memoriy chips just for data loggin so some of must have had same problem I am facing now.
What I want to understand is, how do you guys workaround such limit, i it a real limit?
I have been looking to parallel NVRAM providing unlimited (?!?!?) read/write cycles but they are too expensive to play with.
Please shade some light [noparse]:)[/noparse]
Thanks!!!!!
Nicola
Thanks!!!!!
Nicola
EEPROM (or even FRAM) is not good when you're going to have high speed continuous access to the memory. Flash EEPROM doesn't wear out on reads, but wears out as you indicated on writes. Writes also take a long time (milliseconds). FRAM is faster and more durable, but wears out with read or write cycles and, if you're accessing memory every few microseconds, it only takes a few hours to wear the memory out.
There are some memories that combine a SRAM with unlimited and fast access along with EEPROM used only on power on/off cycles, but it's expensive as you mentioned.
Can you use plain SRAM. It's pretty cheap. In parallel form, it's available in 32K byte and (I think) in 64K byte sizes. If you don't need the speed, you can also get 32K byte SPI SRAM. You could even put a couple in parallel to ease the speed hit (by transferring a block of 4 or 8 bytes at a time).
It will draw the image in memory and the display is b/w 800x600 with an estimated refresh of half second...so I would say planty of time...
I will follow your suggestion and I will look for SRAM...but, still, what kind of application will accpet the limit of read/write cycles besides data logging?
Thanks Mike
Thanks!
What I'm getting at is let's say the image is written to something cheap, that does not tolerate tons of write cycles. Maybe don't write to it at all!
Break the display into zones, or build it like a scan line renderer used often here for games.
For each scan line, fetch the primary image from the bulk storage device.
Then mask in the changes from small RAM buffers
Draw!
That way, you only use a little bit of RAM for those things that change, leaving your choice of devices high.
Chat in real time with other Propellerheads on IRC #propeller @ freenode.net
I am curious though, does this monitor actually scan that slowly (once per second or so) or is that how often the image in memory is updated? That will make a difference to the circuitry. Also, do you already have the circuitry for this and just need the memory?
In the current solution I have divided the screen orizontally in three tiles and I generate and transmit one part at the time.
The system works but there is a lot of overload due to the fact I have to manage object that appears on more then 1 "tile".
I use only three tiles because I could have many small object to display and I do not want to loop several time to draw each tile.
In order to do so, the memory buffer I use is quite big (800x600)/3/8=20KB.
I was looking for a simpler solution in order to free up memory and draw objects only once.
Do you have a specific chip in mind? How to interface it?
Doug
Another tidbit, have a read of the list on the right-hand side for a crazy list of memories.
I would suggest the Cypress CY7C1019DV33 128Kx8 ram.
You will need 17 address lines (16 if you only want to use 64K), 8 data lines, and 3 control lines (*CE, *WE, *OE) for the chip.
These could be taken directly from the prop I/O pins if you had them to spare, but most likely you do not.
You can use 8 I/O pins for data and 5 I/O pins for control lines, 3 8 bit latches to hold the address and *CE.
If you want you can use the 6 unused outputs of the third latch for outputs.
Take a look at Dennis Ferrons Propeller Laptop project to see something similar. The only thing I would suggest is using 74AC574 latches instead of the 244's. Easier to wire the 574's.
If you really want to use the absolute minimum number of pins you can use shift registers to get the address out and data in.
Memory has got confusing. Back in the olden days you didn't have memory that "wore out".
Luckily the chips that don't wear out, ie static ram chips (SRAM) are still around, and in lots of sizes from 2k up to 512k (and probably further).
Static ram chips can usually be configured to retain their memory with a battery backup using a cheap DS1210 chip, and that works out a lot cheaper than non volatile ram packages.
But you don't need permanent storage here. You just want a ram chip you can read and write millions of times. And it will be millions of times, probably millions of times in a few seconds.
There are stores with so many ram chips it gets confusing. I kind of like futurlec because they seem to have what I want but not much stuff I don't want, so less to wade through. This page summarises the sort of ram that you could use: http://www.futurlec.com/ICRAM.shtml Just watch the 5V/3V issue - though this seems to be easily fixed with rows of 1k resistors. Or sram chips that run on 3V. This could be as cheap as $2.90 plus 24 resistors.
Post Edited (Dr_Acula (James Moxham)) : 1/4/2009 6:53:28 AM GMT
Just to throw a spanner in the works, have you seen Andre's HX512 SRAM card for the Hydra?
that is 512KB which is ample for your requirements, but it comes with pre-written ram read/write routines, etc.
might be an easier route for you? it also only needs 10 io pins iirc.
http://www.xgamestation.com/view_product.php?id=43
I considered that since I will probably write one byte at the time but I will read at least 1 KB at the time and send it to the display, I will use a counter to set up the address, does it make sense to you?
One more question, I would like to make it a little bit more difficult.... I would like to share pins between display and memory (they both have chip-enable) so they have a bus in common, what kind of circuitry should I use? I believe that soldering the pins directly to the common bus wouldn't be a good idea....
Nicola
Baggers is right about the HX512 ram card although I counted 12 lines in the block diagram not 11. If it would work for your application it is the easier way to go.
1. Baggers is always right.
2. Andre includes a lot of information with his little card ... very clear documentation that might be the shortest path to your goal.
AND if you want to do more... he also includes tools and documentation that will take you beyond his card if that is where you choose to go.
Very interesting project.
Rich
I see a lot of new things for me... HX512 seems to cost $60...I was looking for something cheaper...
My system is not so "high tech" to require such memory system but I like it..indeed...
I'll try to put all your comments together and come out with some smart design (well...forget about "smart" [noparse]:)[/noparse] )
Thanks again
For Example: Using two 74HC374 Octal D-Type Flip-Flops (or 74HC373 Octal D-Type latches) to create a multiplexed 8-bit parallel data bus with 16 bit parallel address bus, and connecting two 32 kbyte 62LC256 (and equivalents) SRAMS. These old SRAMS are quite common on E-Bay. They are usually 5 Volt parts, so the usual steps have to be taken to interface them to the 3.3 Volt Propeller. The chips usually have 70 ns or slower access times.
P0-P7: DATA0-DATA7 / ADDR0-ADDR7 / ADDR8-ADDR15 <- to data bus on both SRAMS, and latch inputs
P8: ~WE <- to both SRAMS ~WE
P9: ~OE <- to both SRAMS ~OE
P10: LOW_CLK <- To 74HC374 that outputs the low byte of the address to the SRAMS
P11: HIGH_CLK <- To 74HC374 that outputs the high byte of the address to the SRAMS
P12: ~CS0 <- to the first SRAM chip select
P13: ~CS1 <- to the second SRAM chip select
If you are really constrained for I/O pins, one can even use 74HC595 and 74HC165 parts to do it all serially, but it makes access much slower.
Post Edited (Andrew E Mileski) : 1/6/2009 7:29:21 PM GMT
