Asm code for Fram?
Hi folks,
Has anyone done some simple ASM code for the Fram chip?
I am using a FM24C64 and can control it OK using the i2c Spin code.
However, I need to minimise the overall writing time, by eliminating the Spin time overheads, thus the need for ASM code.
I have looked at the SdspiFemto.spin, which has ASM coding for i2c and SPI, but it seems overly complex for a Fram.
kenmac
Perth, Western Australia
Time Zone = GMT + 8
kenmac
Time Zone = GMT + 8
I need some help in understanding the description of operation contained in the file.
The following is an extract of same:
It says the control is 2 longs, stored somewhere in Hub memory.
As I understand from the diagram, the command/status is in the MSB byte of the first Long.
I don't understand the comments re "I/O pin pair" being in bits 19..21, and is the SCL pin divided by 2?
OK, SCL = pin 28, so that means 14 is the I/O pair??? How does that relate to the bits in Pins 19..21?
The device address is the chip select bits?
The 64K address bits is the device's memory location?
Where does the device ident. code appear e.g. an Eeprom/Fram = %1010xxxx ?
The 2nd Long seems to have the byte count in the MSW and the Hub address in the LSW.
I assume the Hub address word is the pointer to where the 2 Longs are stored?
Is the byte count referring to the page size? e.g. 256 bytes requires the 2 bytes
For a Fram chip, this Word would be zero ?
That's a few queries to start off.
Happy New Year to all,
Ken Mac
Time Zone = GMT + 8
The address of the 2 long control block is passed to the assembly routines when they're started in their own cog. The high order byte of the first long is the operation and status code. It should be the last thing set by the user since the assembly cog is looking there for something to do and will immediately fetch and decode the control block when the command bits are non-zero. The other 3 bytes of that long contain the EEPROM / FRAM starting address to be used.
It's possible to attach up to 512K bytes of serial memory to every even/odd pair of I/O pins for a total of 8MB of storage. These routines handle the EEPROM address that way and derive the I/O pin numbers and device select code from the high order bits of that 8MB address. The "I/O pin pair" bits are bits 19..22 and represent I/O pins 0/1, 2/3, 4/5, 6/7, ... , 30/31. Bits 16..18 are used to construct the device select code since there are 8 possible EEPROMs on any one I2C bus. Bits 0..15 are used as the address for the EEPROM. For EEPROMs less than 64K, the high order bits are ignored. For EEPROMs larger than 64K, multiple device select codes are used.
The hub address in the 2nd long is the address where the data transfer is to be made (read or write). The byte count is the number of bytes to be transferred. For reads, the data cannot span two separate devices. It has to reside completely within one device (64K or less). For writes, the data has to fit within a single "page" which is defined by the device. Usually this is 64, 128, or 256 bytes depending on the device.
These routines can also handle non-memory I2C devices. In that case, the entire device select code and 0, 1, or 2 bytes of control information are provided in the 24 bit "EEPROM address" field as described in the comments.
These routines also handle low level SPI operations using additional operation codes. These are intended specifically for SD cards. You can ignore them if you want.
Look at the various Spin interface routines to see how the commands are constructed. These mostly start with a wait for completion of any in-process operation, start a new operation, then wait for completion of that.
Post Edited (Mike Green) : 12/31/2008 3:01:01 PM GMT
So the I/O pair bits are actually 22..19, not 21..19 as described?
That makes more sense - I couldn't see how the number 15 could be represented by three bits.
OK, I don't need to know how the ASM code works if it can work "as is " for a Fram chip.
What I do need to understand now is the correct method of using the Spin parts to control it all.
So, could you please give an example of implementing the following:
Write one byte to a Fram at location $1F40, the chip address = %001, pin pair = 28/29
kenmac
Time Zone = GMT + 8
OBJ i2c : "sdspiFemto" VAR long controlBlock byte dataByte PUB test i2c.start(controlBlock) if i2c.writeEEPROM((28 << 18) | (%001 << 16) | $1F40, @dataByte, 1) ' an error occurred, perhaps the EEPROM or FRAM is missing else ' successThe left shift of 18 takes into account that the even "pair" number starts at bit 19.
Initially I was a bit confused by the "28<<18", (I thought it should be <<19 ) but eventually I realised it was just performing the required "SCL/2" function, and being the "even" number, the lsb will always be 0, and thus won't affect the msb of the chip select number(bit18) if it is set.
Anyway, I tested it and it works OK, so I'll work from there.
Questions -
What is the write speed used there?
Can it be set up to run at Prop. clock speed? (Fram can read/write at clock speed )
kenmac
Time Zone = GMT + 8
SPI FRAMs can run at clocks up to 20MHz. It's a real challenge to get the Propeller to do SPI at anywhere near that speed.
Post Edited (Mike Green) : 1/2/2009 5:42:05 AM GMT
I have the particular Fram's datasheet with the info on the required protocol, so I might have a go at some "bit banging" to control the Fram.
It won't be immediately tho, there are some higher priority projects beckoning.
kenmac
Time Zone = GMT + 8
