Parallax 4x20 Serial LCD with Keypad Interface Graphical
So after having this thing for about 6 months now, and taking I can’t count how many attempts at making it work…
http://www.parallax.com/Store/Accessories/Displays/tabid/159/CategoryID/34/List/0/Level/a/ProductID/55/Default.aspx?SortField=ProductName%2cProductName
I can get nothing more than gibberish on the screen.
I have tried every baud rate I can think of. Various wiring configurations, including pull ups and downs. ·Standard serial driver, the Full duplex driver (every possible mode configuration), and anything else I can think of.
So has anyone ever made one of these work? How? Anyone have a driver that they know works for this screen?
TJ
TJ
Bah! Spoke too soon. I have the unit without the keyboard interface. Sorry.
Post the code that is failing and let's see if the group can narrow it down..
OBC
New to the Propeller?
Check out: Protoboard Introduction , Propeller Cookbook 1.4 & Software Index
Updates to the Cookbook are now posted to: Propeller.warrantyvoid.us
Got an SD card connected? - PropDOS
Post Edited (Oldbitcollector) : 1/1/2009 8:42:12 PM GMT
I'm absolutly sure that parallax sells reliable products.
Nevertheless it might be that your LCD has a fault.
Parallax itself has got it working.
To narrow down the problem regardless of what the fault is: we need ALL kind of information.
As long as you just cry out for a driver NOTHING changes.
As it's interface is TTL serial FullDuplexSerial MUST work if everything else is OK
So PLEASE PLEASE PLEASE provide ALL the information
the LCD needs a powersupply of 5V and minimum 100mA
Did you test the LCD with a terminalsoftware and a voltage-levelshifter-cable ? (turning TTL 0V/5V into +12V/-12V)
Did you test your propeller-chip with a terminalsoftware on a PC ?
Did you talk or mail with the parallax tech-support As the most professionals you can get for advice ?
Could you post a schematic of that setup which you think SHOULD work best?
Can you ATTACH your COMPLETE code to a posting (not only pieces posted directly)
Can you post pictures of your COMPLETE setup ?
Do you have an oscilloscope for watching the bitbanging on the serial wire ?
If you have no oscilloscope can you switch the serial line high/low every 3 seconds and measure the voltage with a DMM ?
I'm sure we can find the fault but only if YOU provide enough information !
best regards
Stefan
Post Edited (StefanL38) : 1/2/2009 12:17:45 AM GMT
Why I asked if anyone else had any experience with one...
With a bs2, javalin... If they had a driver in the obex for the prop..... Since you do not own one of these, please note
http://www.parallax.com/Portals/0/Downloads/docs/prod/audiovis/LK204-25-Errata-V1.2.pdf
The one parallax sells has the 9 pin removed and is configured for TTL logic.
See attached for the "Driver" I wrote....
The following code generates this
lcd.Start(10,11, %0001, 19200)
OBC
The idea is every time I press the button I send the char So I can see what is being sent per loop.
Ok so here is what is weird. Sometimes I get an h, sometimes I get an x, or both, with neither one being always 1st. So on any key press I get one of the following options. h, x, hx, xh, hh, xx. I am very lost here.
Also included are the requested pics of the setup, and serial com line.
I also tried the Spark fun logic level converter. To test the possibility of it being a voltage mis match issue. Pictures included, on the next post, Limit 5 per post I guess.
Thank you for the help,
TJ
Post Edited (TJHJ) : 1/2/2009 9:47:13 PM GMT
TJ
See picture for char being printed per key press.
Its the char that looks like a dash on the top of the char slot.
TJ
For instance, try communicating from PST to the LCD first and see
if you can get proper communication from the PC to the LCD over
the programming plug. (30,31)
OBC
I get the same results using the prop terminal, the random assortment of h and x, I used a prop plug to act as the USB to serial converter, I am not sure if this is really ok.
I also downloaded the test software, and tried to run it using the prop plug as my converter. I get nothing but fast scrolling gibberish no matter what settings I use.
I can try. StephanL38 has been kind enough to try and help me through PM as well. Here is the summary of things I have tried.
The questions are StephanL38's. Thanks again Stephan....
1.) check the frequency of the crystal for the prop
maybe there is a wrong or bad chrystal mounted
to check this: hook up an oscilloscope the check the timing of the serial bitbanging
I am hesitant here, The prop runs terminal application fine for com, So I would assume that the timing is ok. Just to double check I hooked up a standard 4x20 display that I have used in the past and it works just fine.
2.) maybe for some reason the voltage-levels for a HIGH is just around the threshold-value
of 1.6V.
Check this with an oscilloscope
I am seeing a solid 3.301v as the high output, Picture on thread.
As a test, I have the Spark Fun logic level converter, I placed it in between to kick the voltage all the way up to 5v, and there is no change in its behavior.
3.)> If you change the rx and tx pin to Pin-No 31,30 so that your code of graphicLCDTest.SPIN looks like this
lcd.Start(31,30, %0000, 19200)
>you can check your driver with PST.EXE or any other serial terminalsoftware
>in fact you can use the SAME serial connection that is used for programming the propeller for debugoutput via
>FullDuplexSerial
>If you get the same bytes on the PC as you sended them out YOUR DRIVER IS ALRIGHT
When I switch the com lines to 31,30 and display it into the PST tool, It displays perfectly Fine.... Damn
4.) >Did you check the "Protocol Select Jumpers" like described in the manual on page 11 chapter 2.3 ?
>If you are using a direct connection to the Prop it should be configured for TTL
>This means there have to be soldering bridges in across the soldering pads named "TTL"
>and the soldering bridges across the soldering pads named "232" have to be removed
>did you check if there is contact on "TTL" across the soldering pads ?
Ok I took my multimeter and checked the connections using the toner. And it is not showing any measurable resistance. So I think this is good.
5.)>did you check if there is NO contact on "232" across the soldering pads ?
No tone, Visual inspection shows a solid separation, no connection error on resistance measurement.
6.) Check the timing using an oscilloscope.
It is ok and correct.
7.) Tx and Rx lines. Tried both ways.
8.)
'' mode bit 0 = invert rx decimal value 1 or binary %0001
'' mode bit 1 = invert tx decimal value 2 or binary %0010
'' mode bit 2 = open-drain/source tx decimal value 4 or binary %0100
'' mode bit 3 = ignore tx echo on rx decimal value 8 or binary %1000
>did you test all these modes with THIS values?
using the following code.
This just changed the mode every time I press the button, so I could ensure that I checked every possible mode.
The blinking LED just let me keep up with what the value for i is.
I used a similar method to test all the baud rates.
and finally this code to check every possibility of either.
Thank you all for trying to help me with this.
TJ
Post Edited (TJHJ) : 1/3/2009 7:32:36 PM GMT
·I purchased one of these unmodified from Digi-key and was was able to first plug it directly into my serial port and use the Matrix orbital software to play with it.· Out of the box it should have run at 19.2.· I then had to move the jumpers from the 232 to the TTL· points.· My connections are from P0 on the Prop·to the RX of the display and P1 of the prop·to the TX on the display.·
I get the odd character that you show from yesterdays post (2:06) prior to when the Propeller initializes the serial port using the Full Duplex Serial driver.
I have included a half finished spin project I was working on using this display and it's keyboard interface.· It includes a routine called matrix_lcd that is the modified·Parallax Serial LCD Driver v1.2·· made by Jon Williams and Jeff Martin.· I modified routines to work with the Matrix display, and added routines to make the keyboard function.· It isn't clean (but the display and keyboard work) because I decided to move on to C· with the project.·
If this doesn't work, it almost sounds like the baud rate is messed up.· Try the manual override jumper located on page 13 on the matrix LK204-25 manual.· It said this will reset the Comm. settings.
Hope this helps.
Let me know if the attached zip file doesn't come through, it's my first attachment try at this forum.
THANK YOU THANK YOU
I cant seem to spot where the difference is in the code... But Ill spend some time later looking at it.
Thank·you so much RudyC.
TJ
as far as I compared the Serial LCD Driver from parallax and matrix_lcd
matrix_lcd sends commands for setting up the keypad
and then woodstove - main calls
lcd.cursor(1) ' cursor off
lcd.DisplayOn ' Display on (if available)
as first operations.
@TJ: I'm so curious about this could you please make a test what happens if you comment-out
the putc commands in the init-method of matrix_lcd.spin and
and
in the main-method of woodstove.spin ?
the original Serial LCD Driver from parallax uses simple_serial instead of FullDuplexSerial
so I guess it doesn't matter using simple_serial or FullDuplexSerial
the debug_LCD-demo does
so is the bug simply a leading command lcd.cursor(0) ? ??
TJ please check this for me ! I'm so curious about what the bug was
Thank you in advance
best regards
Stefan
Post Edited (StefanL38) : 1/4/2009 9:26:51 PM GMT
I started with the simple serial driver from the obex.· I then moved to the Full Duplex driver, to spread the tasks across to another cog.·
the lcd.cursor routine is to change the cursor type on the screen.· the displayon routine turns on the backlight.· In the routine, the last putc has a value that is the number of minutes that the backlight stays on.
The code wasn't complete because I moved on to C before I completed the spin code.· The reason the cursor and the display on are at the beginning, because I got it as far as functional.
