DTMF circuit
Hi All,
I'm messing about seeing if I can come up with the parts to try the DTMF circuit in the BS manual. I have a couple questions about component substitutions.
1) Xfrmr. I have a couple of 800/1800 ohm ones that I could couple back to back. I also have some 50/50 ohm isolation transformers, and a few modem xfrmrs of various values. How close do I need to get?
2) I don't have any SIDACS. I do have some MOVS, part #ZNR10K20IU and ZNR20K20IU, I can't seem to find data sheets on these. How crucial are they? Can I play with it to get going without ad order some, or am I going to blow something?
Thanks!
Jonathan
www.madlabs.info - Home of the Hydrogen Fuel Cell Robot
Thanks!
Jonathan
Leon
Amateur radio callsign: G1HSM
Suzuki SV1000S motorcycle
I find it hard to beleive that a 1:1 xfrmr driven by a Stamp can injure anyone. Mess up phone equipment *mayve*. I think the SIDACS are there to protect the user and stamp from voltages coming down the line. I got it to work with the xfrmrs I have and I have ordered the SIDACS just to be safe.
Thanks!
This covers the sort of things you need to take into account:
www.cermetek.com/catalog/Telephone-Line-Interface/DataSheet/XE0068DTRevC.pdf
Leon
Leon, thanks for the link, it's a good read. With the SIDACS, I think I'll be ok. The mains power is well isolated from the phone circuit, so I think I'm OK there.
Did you consider using a Data Access Arrangement ( DAA ) verses the transformer? A DAA will give you ring detection, hookswitch control and bandwidth for voice grade applications if you ever wanted to include a EMIC - Also provies 1500 volts isolation between tip/ring and the rest of any circuitry.
