How many PWMs can I generate at the same time with SX28ACDP ? — Parallax Forums
markustermarkuster Posts: 184
edited 2008-12-31 17:27 in General Discussion
Hi,
with SX28ACDP ?
Thanks, Mark
  • ZootZoot Posts: 2,227
    edited 2008-12-31 14:43
    Theoretically, you can put PWM on every I/O pin if you wanted (20). Practically, the answer would depend on what PWM frequency range you want, and at what speed you will be clocking the SX. There is no hardware PWM on the SX, so you can write as many "virtual" PWM generators as you want.
  • JonnyMacJonnyMac Posts: 9,759
    The attached framework shows how to do eight PWMs -- as Zoot states, it's easy to extend this to all available pins.
