suitable higher current replacement for ULN2803
Hello,
I need to switch ledstrips circuits from propeller, each circuit is 1.2A at 12V, ULN2803 or ULN2003 can output 0.5A at most (and that is with paralleling all inputs/outputs). I am looking for something similar to a transistor array as I have 40 ledstrips circuits to switch. The board size is limited too, so I am looking for a space saving solution (so no TIP mosfets). I cannot find anything that would fit the bill, could someone point me in the right direction?
You have a lot of power to drive -> You´should have space for work, and to refrigerate them.
Regards.
Alberto.
www.micrel.com/page.do?page=/product-info/products/mic4426.shtml
Leon
Amateur radio callsign: G1HSM
Suzuki SV1000S motorcycle
Thanks!
I am not familiar with the drawback of most transistors but this one seems suitable www.zetex.com/3.0/product_portfolio.asp?pno=FMMT617, any opinion?
There will be a ventilator in the enclosure, blowing directly on the chips, and if necessary some heatsinks.
Post Edited (jeromelab) : 12/31/2008 10:33:43 AM GMT
TI sez... Mouser has the 5926 flavor (w/ 256 gray) for $1.57 each. Only 120ma though.
Post Edited (Fred Hawkins) : 12/31/2008 5:43:18 PM GMT
Just use two boards in sandwich if you need more space, or three.
Try a first assembly with only one IRF and test it for many time, check temp, time ressponse, drop voltage, etc.
Warning, it is reccomended that you use a resistor in paralel with the mosfet gate and gnd.
Regards.
Alberto.
This one hits 1.2a but only one output. Comes in two bug-on-the-plate arrangements -- how's your surface mount handling?
http://focus.ti.com/docs/prod/folders/print/tps61050.html
Post Edited (Fred Hawkins) : 12/31/2008 11:55:27 AM GMT
For 12V non-inductive loads you can just run these directly from 3.3V logic and although you will need 20 of these to drive your 40 ledstrips the devices take up less space than the connectors. Just think of a little black dot next to every two outputs.
Obviously the Prop doesn't have 40 I/O lines so I guess you would just use five cascaded 74HC164 or 74HC595 shift registers to drive the MOSFETs.
*Peter*
If I read this one right, it's a 595 8bit·shift register (cascadable like usual) that handles 350mA of 50v on each line. There's four flavors of this chip with various ratings:
tpic6595 45V 250mA continuous, 1.5A pulsed peak (only 2% duty though, 100µs duration)
tpic6a595 50V 350mA continuous, 1.1A pulsed peak (ditto on limits for this and the rest)
tpic6b595 50V 150mA continuous, 500mA pulsed peak
tpic6c595·33V 100mA continuous, 250mA pulsed peak
Then there's the TPIC6596. I don't get the difference, but the logic block diagram is slightly different.·It's 45V 250ma, but has a 2A pulsed peak.
