dish antenna positioner using quad optic sensor. — Parallax Forums
bondissementbondissement Posts: 2
edited 2008-12-31 06:19 in Learn with BlocklyProp
could u pls help about this project ? ..
i m gonna use quadratic sensor to give positionto the antenna ..
i ve attached a picture to help you to understand..
thanks for everythng..
    edited 2008-12-30 05:39
    I don't know where you'd find a ready-made 4 quadrant light sensor, but it ought to be easy to build using a lens (perhaps a round Fresnel lens) and a home-made quadrant baffle using thin wood or foam-core sheets and a plastic bowl painted flat black. The RCTIME in Stamp Basic can be used to measure the light intensity in each quadrant (one at a time, but fairly quickly). Read the Stamp Basic Manual chapter on the RCTIME statement for details. There may be useful information also at www.emesystems.com at the "app-notes" link at the bottom of the page.
    The Nuts and Volts Column #6 deals with controlling relays, solenoids, and small motors with Stamps.
    The index is here:www.parallax.com/Resources/NutsVoltsColumns/tabid/272/Default.aspx
  • Capt. QuirkCapt. Quirk Posts: 872
    Why don't you just hack one of these to control your X, Y axis.
