dish antenna positioner using quad optic sensor.
could u pls help about this project ? ..
i m gonna use quadratic sensor to give positionto the antenna ..
i ve attached a picture to help you to understand..
thanks for everythng..
The Nuts and Volts Column #6 deals with controlling relays, solenoids, and small motors with Stamps.
The index is here:www.parallax.com/Resources/NutsVoltsColumns/tabid/272/Default.aspx
