Using a Digital Picture frame for a display
Any one got any ideas on how a guy could use a digital picture frame as a display? It has a USB port that I can send data to from the Propeller. Problem is that I am not sure how to send data that looks like a jpeg, or bitmap. I bet if I could send data out as one of these file types it would work.
jpegs are compressed by a more or less complex algorithm. If you would like to update this picture in realtime this will go over the capabilities of the propeller
Bitmaps need a lot of memory.
So if you search for a cheap display take one of these portable DVD-players or small portable TVs with a videocomposite-input.
The propellerboard has an USB-plug which interfaces to a PC by building a VIRTUAL COM-PORT (RS232-com-port) This could be used ONLY for transfering RS232 data
NOT for pure USB-data like USB-sticks or something like that. Therefore you could use a Vinculum-USB-adapter. But then I think it's much easier to take a TV-screen
or VGA-monitor right from the shelf
best regards
Stefan
After my 5" CRT died, I found a Sony DVD player with a Video In port which I now use. Nice unit and can display in color, if desired. Attached photo of it shows the headings of my two Props in different colors. A LCD mode switch displays either in 4:3 or 16:9 format; nice and readable in 'wide screen'.
Harley Shanko
A portable DVD or something with video in is definitely an easier and probably better way to go...
No dice! Hit Ebay for a portable DVD player with a broken mech. Make sure it has AV-IN (most do)
and you'll have a cheap/portable AV screen for your prop. Last one cost me $11 shipped.
OBC
New to the Propeller?
Check out: Protoboard Introduction , Propeller Cookbook 1.4 & Software Index
Updates to the Cookbook are now posted to: Propeller.warrantyvoid.us
Got an SD card connected? - PropDOS
Post Edited (Oldbitcollector) : 1/21/2009 3:23:10 PM GMT
the nice thing for both is they run off 12 volts the backup display is really nice and portable and the colors look nice
I hooked the hydra up to them to play games nice monitors
Very clever, your "dual-port" SD card! I like it!
It has several ICs:
Sunplus Multi Media SPMF-2800 processor (No data on the Sunplus site :-(
A MC34063 to control the backlight.
A 16 MB SDRAM CT51V641601
Another 8 pin SOIC (a bit wider than a SOIC) called ?D80VS1G
Another SOIC-8 called 3414E
One 5 pin SOT-23 ic.
And a dislay marked: B15GN8B100517 in a sticker. The flat cable says something like H430A35
Well, that was a waste of money :-( (59 €[noparse];)[/noparse]
I do not have here the Oscilloscope and I do not think is safe to connect the logic analyzer directly to the TFT pins due to the possibility that is has some high voltage (the la supportas only from -6 to +6). Tomorrow I'll see if I go to the uni and have a better look at it.
This datasheet: http://www.gblcd.com/datacenter/hannstar/HSD070I651.pdf is of a very similar TFT but with CCFL backlight, mine is LED.
The display corresponds to what it is described in the datasheet, same maker.
Most signals are 5 V based, even analog ones. The oddity of these kind of displays in the necessity of generating both odd and even frames with alternating polarity for the signals. Once 5V means maximum brightness, next frame it means minimum. Obviously this was thought for using this kind of display with NTSC composite signals, well with split RGB. Still utterly complicated without too much sense (for me).
Note: In the circuit I have, the pixel clock signals are sinusoidal and not square.
Of course, once you've got the firmware hacked, no need to use USB or any prior protocols, replace with a serial link and a simple terminal / pixel map driver, just set the pixels on-chip and watch the display light up.
One example : spritesmods.com/?art=picframe
Unfortunately, "that's fine, but where do I find the exact same frame" ? Unless a ubiquitous over the counter product suitable for hacking by one and all can be found any effort in that direction is going to be rather a niche market and solo effort at best.
The DVD players are plummetting in price. Maybe you could get a dual screen one and nick one screen for a propeller and put the DVD + the other screen in the santa stocking for the kids and pass it off to the missus as a gift purchase rather than wasted money on that 'darned electronics' hobby?!
The RCA input seems standard. Broken ones don't seem to be on local ebay and international shipping adds to the cost so the new package still is $100. But they were $399 only 18 months ago. It makes sense to tap into something that is mass produced for a screen and this could well be the answer over the next 6 months. I'm sticking with a freebie vga crt for the moment but watching developments very closely re these 7-9 inch lcds. They are already much cheaper per character than 16x2 and 20x4 LCD displays. As a general statement I think it would be wise to put both TV and VGA on any board based on the propeller.
Post Edited (Dr_Acula (James Moxham)) : 1/19/2009 2:16:31 AM GMT
I am now building a bigger version of OBC's portable propeller system. The nice thing about this is that somehow there is a empty cylindrical compartment at the back (where the Screen swivels). This was probably meant for a lithium battery. Well, the best part is that this is were I am going to move the PS2, vga, serial , and other connectors instead of mounting them in the Proto board. This will allow me to install the proto board and still be able to close the player. The power supply is 9V - perfect for the propeller's requirements. It also has all the AV inputs that I need to interface the protoboard. This will give me the option to connect my Hummer DTV (C64-8bit clone -- see PETSCII.com ) and use this broken DVD player as a monitor.
Thanks to OBC for all the ideas...
I've got one that's been begging to be done for months and simply haven't gotten around to it.
(Need to win the lottery so I can do Propeller stuff 24-7.
OBC
