555 Timer
Good Evening Everyone,
··· I am trying to build a circiut using the 555 timer to produce a square wave that has an on time of .5 seconds, and an off time of .5 seconds.· After reading the datasheet I found some formulas on page 11 to calculate the size resistors to use given a certian size capacitor.· Either I am doing some bad math, or what I want isn't possible in that application (astable operation).· If any of you have some experience with this component I could sure use some help.· Thanks in advance.
P.S.· Why do they use subscript for the parentheses in some occasions and others they don't.·
There are 10 types of people that understand binary, those who do, and those who don't.
www.kpsec.freeuk.com/555timer.htm
JJ: You can't quite get 50%, but close. Per Mike and that great site, you must add a diode in parallel with R2 to get below 50%.
Without a diode, it looks like R1=10K, R2=100K, C1=10 uf (that's .00001 F in the calculations) will give you 0.645 hz and a duty cycle of 52.4%. You want 1 hz, so you can either use a third-smaller cap or resistors, depending on·what parts you have handy.
I think they just didn't have a word processor that handled the parentheses properly.
Chris Savage
Parallax Engineering
··· Can you reference some of those chips, so that I may review them.· Thank you for your reply.
Here is the Link to it
·Here for·the·DS1302Time Chip
Make sure order one of theses as well
Here·for 32.768 kHz crystal.
Look at a DS1302 Time Chip that PARALLAX sells that should work for and there
Demo code for this chip·as well
··Thanks for any·
Sam
Post Edited (sam_sam_sam) : 12/30/2008 1:25:38 AM GMT
If you need more help choosing parts please post detailed information on what you want to accomplish.
http://www.parallax.com/Portals/0/Downloads/docs/books/sw/Web-SW-v2.1.pdf
Hopefully that will get you on your way.· On the other hand, maybe you are avoiding using it for some reason ???
Good luck with your project !!
Charlie
