Christmas lights that actually twinkle.
potatohead
We end up talking about this every year. Thought I would post it up here just to see what people have to say.
The old 110V dangerous Christmas lights were wired in a simple parallel circuit. All of them were colored, with simple colors. Red, blue, violet, green, etc... Each had the simple mechanical flasher device, where current flowing caused the metal to expand, thus breaking the circuit. (maybe just heat from the filament, never knew) The imperfections in manufacturing more or less meant each light kind of did it's own thing.
At night, it was fun to just watch the tree as all the different cycles working together made for interesting and fun patterns, and the lights on the ceiling were just great too. More cool patterns.
In this day of lower voltage (and clearly safer) lights, this was lost. We've got patterns of different kinds, fade in, fade out, etc.. We've got more colors now too, which is good.
But... nothing just twinkles, and we miss that enough that I'm half tempted to just go find a set, and manage the things so they are safe, and watch them again.
Is this just an oversight for cost, or what? Maybe nobody cares?
Is it possible to make a circuit where lower voltage lights, maybe the flasher ones, can just twinkle like the old ones did?
Chat in real time with other Propellerheads on IRC #propeller @ freenode.net
Andrew Williams
WBA Consulting
IT / Web / PCB / Audio
Flasher_LEDs are available in all LED colors, even multi-color.· Wire 'em up.
These aren't in a string, but you can get the idea (?).
Thanks for the link!
Yeah they did all blink at their own rate. Variations in manufacture on the spring that caused the blink, allowed rates from about a coupla seconds, to maybe 15 or so, ramping up as the bulbs got hotter.
RE: Flasher bulbs
All of the strings I have found are in series. LED ones are parallel? Have to check on the current needed. Thanks for that too.
This will probably be a project to get done before the next holiday.
I wouldn't chance this on a real tree, and i use a power bar with circuit protection. You could use some high output leds with some coloured diffusers doing a random thing from software. Whether that setup is any safer is questionable. Just think, in the old days they used real candles on real trees.
