USB->MIDI interface
Has anyone written an object to use the Prop's USB hardware on the Proto board to directly send MIDI messages to a PC running Cakewalk or other similar MIDI program?
I have completed my organ console program (for the most part) and the new PC to be used does not have the 5 pin din input/output interface. I can purchase a standalone converter but as there are still a couple of free cogs on the prop it might make sense to do it in software.
Craig
Craig
there are already some threads about connecting a USB-keyboard. As far as I understood the comments
1.) It seems to be a big challenge to write an USB-stack for the propeller.
2.) The USB-Hardware is a USB-to-serial-interface. It's not possible to use this USB-connector in an other way than as a RS232-interfaceadapter
One solution might be to send the MIDI-commands to the PC to a c++ or delphi-program that is able to send Windows-Messages to the MIDI-software
best regards
Stefan
My program has 2 MIDI outputs one which would be limited to the standard MIDI speed of 31,250 but the other could be a higher baud rate. If nothing has been written I may just use the external converter hardware.
Craig
So yes, it's possible. It's something I have planned to implement in the USB stack for a while, but never quite got around to. The USB code is here in the forum somewhere. It would not be incredibly difficult to implement a class compliant USB Midi interface on top of the low level MAC code already written.
You would need at least 2 spare cogs and 3 port pins and about 3-4k of spare hub ram to make it work.
<edit>
Oh, I just re-read what you originally wrote. Forget about using the on-board FTDI for anything other than usb-serial.
Sorry.. I should have read a little closer
Cardinal Fang! Fetch the comfy chair.
