PING))) sensor temperature
Hi dear crazy friends [noparse];)[/noparse]
I'm looking for a solution to detect when I'm in front of my outside door or not. I'm not very good in electronic so I choosed the PING))) sensor. Very easy to use, and also can tell me if I'm really in front of my door, or in front of my wall (useful after few drinks
My only concern is that I'm living in Quebec and the outside temperature can go lower than -20C in winter. PING))) documentation is showing "Operating temperature: 0 – 70° C.". So I'm fine with the maximum, but is there no way to have it works under 0C?
If this sensor can't works for my project, what should I use to replace it?
Thanks for your suggestions.
JM
)My only concern is that I'm living in Quebec and the outside temperature can go lower than -20C in winter. PING))) documentation is showing "Operating temperature: 0 – 70° C.". So I'm fine with the maximum, but is there no way to have it works under 0C?
JM
Thanks for the idea. The only outdoor light I have is a low power one (27W) and is to far from where I need to place the sensor. Regarding the idea to de-activate it, I can't. This is the system to open my door, so I need it every days [noparse];)[/noparse]
Do I have a way to use a "light" beam or IR or something like that, and put the light on a side of the door acces, and the sensor on the other side? But I have now idea how to do that and which components to use [noparse]:([/noparse]
JM
2) You might want to use IR sensing as an alternative. This is described in the "Robotics with the BoeBot" tutorial.
Ultrasonic and IR distance sensing is very dependent on the materials that make up the object to be detected.
Often one will work when the other will not. You may want to use both methods.
The distance accuracy is not important for me as long as it can detect if there is something new in front of the sensor. So I will take a look at the IR alternative, and maybe by the 2 just to be sure at least one of them will work.
JM
There's nothing like a new idea and a warm soldering iron.
a webpage about it : www.societyofrobots.com/sensors_sharpirrange.shtml
I did not get a chance to do the test yet. So I will try next winter with the PING sensor.
JM
