nuts and volts column#147
Ok Jon Williams stated in column 147 that the nodes use a peer to peer protocol, But i don't see how this would be possible with his nodes. The TX line(Z-Y) of one node is wired to the TX line of all nodes that follow it. the same is true for the RX line(A-B). so it shouldn't be possible for one node to talk to anther. Right? You would need One configured as a master with its TX line tied to the RX line of all the following(slave) Nodes, And the RX line tied to the slaves TX lines. Right. and my final question is would it even be posible to use the full-Duplex Chip(max489) in a peer-to-peer setup? If so how would the network connection be made?
N&V Column #147:
www.parallax.com/Portals/0/Downloads/docs/cols/nv/vol8/col/nv147.pdf
N&V Column #147:
