Should Propeller QFN and QFP chips be made cheaper?
I noticed that surface mounted chips are usually cheaper than their DIP equivalents.
1. Is it because smd chips use less material than DIP chips since they are smaller in size?
2. Or is it because their shipping and storage costs less due to their smaller size and weight?
3. Or is it because chip suppliers know that smd customers will most likely use the chips for production, while DIP chip customers are more likely hobbyists?
If smd chips are used for production, wouldn't it mean that support costs per chip sold is much lower than DIP chips, allowing lower pricing for smd propellers?
www.fd.com.my
www.mercedes.com.my
www.fd.com.my
www.mercedes.com.my
Parallax probably sells far more DIP chips than those in QFP and QFN packages (the main market appears to be hobbyists), so there isn't much incentive for them to reduce the prices of the latter. It's the opposite situation with most other MCUs.
Leon
Amateur radio callsign: G1HSM
Suzuki SV1000S motorcycle
Post Edited (Leon) : 12/24/2008 2:01:22 PM GMT
I get the impression that it's very much a niche market, though, for commercial applications of the Propeller. I can't see anyone designing the DIP device into a product - it's just too big. Looking at the stock levels of the various chips, no-one seems to be using the QFN part, which is what I'd use in a commercial application. It's much better for automated assembly than QFP.
Leon
Post Edited (Leon) : 12/24/2008 4:51:32 PM GMT
Leon
The QFP is also easier to work with from a PCB layout standpoint. The reason is that the underside of the QFN has a large substrate connection which precludes any signal routing underneath the chip, which is just fine with the QFP.
The QFN package does hold a distinct advantage in size, which is a critical factor for some designs. Also, the large substrate connection may yield better thermal behavior if properly exploited for that purpose. But those are it's only advantages, as far as I can tell.
'Just a few PropSTICK Kit bare PCBs left!
I hope for the Propeller V2 that Parallax continues to support home brew hobbyists with DIP packaging.· Alternatives such as PLCC and/or DIP compatible mini boards would be OK too.· Making everything SMT is a show stopper for me.· Its just too hard to work with.· Not impossible just unpleasant.
One idea would be to make an adapter DIP miniboard with pins on the copper side which correspond to four·28 pin sockets mounted in an "H" pattern like this;
HH
HH
That'd give·112 pins which should be sufficient for QFP 100 SMT chips.
Thanks and have a nice day!
Andrew Lynch
[noparse][[/noparse]Edit]
I just created the QFN footprint for the Propeller (it only took a few seconds with the Pulsonix Wizard), and updated an existing schematic of mine.
Leon
Post Edited (Leon) : 12/24/2008 8:43:29 PM GMT
Also the Propeller also has a certain market value, to consider.
Leon
Got a link?
BTW I know of a commercial product here in the UK that has two propellers in it, one is a DIP and one is QFP.
Coley
PropGFX - The home of the Hybrid Development System and PropGFX Lite
What is the reason for using both a DIP and a QFP in the same system?
Leon
In future products for my day job or for Brilldea I consider either the QFN or QFP to be the chip of choice and usually it is the QFP first. Now that I have my DIY reflow oven I may try the QFN as it was not something I wanted to try by hand soldering just yet though I know it is possible.
Timothy D. Swieter, E.I.
www.brilldea.com - Prop Blade, LED Painter, RGB LEDs, uOLED-IOC, eProto for SunSPOT, BitScope
www.tdswieter.com
I don't know tbh, I never asked the designer
I would guess that as it was two distinctly seperate PCB's in the design, one were space was a constraint and the other wasn't.
The only problem with surface mount product is having boards 'in stock' usually means they are fully assembled (if you are not doing them yourself) and therefore money sat on the shelf, cashflow is king in business so unless they are fast moving sometimes DIP and thru hole is the best way to go.
Thanks for the link.... Merry Christmas to you all
Coley
Post Edited (Coley) : 12/25/2008 1:15:17 PM GMT
I've been playing around with a single-sided proto board for the QFN device which I can make at home, and came up with this breakout pattern:
[img]http://www.leonheller.com/Designs/QFN (BO).GIF[/img]
It puts the breakout pads on 0.1" centres, like the Parallax proto board.
Timothy might be able to use something like it.
Leon
Why not go the whole hog and drop on a footprint for some decoupling caps and a crystal, would make a nice board then
Coley
How about this:
[img]http://www.leonheller.com/Designs/Prop module.GIF[/img]
The QFN is on top and all the other parts are on the underside.
Leon
Post Edited (Leon) : 12/25/2008 3:02:24 PM GMT
It's 1" square!
The other parts should fit OK. There is even room for a reset button.
Leon
Post Edited (Leon) : 12/25/2008 4:50:48 PM GMT
Perhaps someone will beat me to this, but it is something I would like to do.
Merry Christmas!
www.tdswieter.com
