Binary Operators
                    Trying to write in code that controls waste oil heater, I am using a DS2760 thermocouple and a SX28 that , what I would like to do Is set a output high and then turn it off and stop the program when the temp gets over 140 C degrees . The SX dose not have a Binary operator > greater than which is what I have used in the past with basic Stamp. If I use the code in the SXB editor it runs but wont work. Shutdown is a Sub that turns off the pin that drives a AC relay. Thanks David
Basic code that works ======== IF tempF > 340 THEN LOW OT1
SXB code ================ IF tempC => 140 GOTO Shutdown
The reason is that IF-THEN implies a GOTO (compiles to JMP @Label), not GOSUB (compiles to CALL @Label).
· The technical term is is "borrowing" code [noparse];)[/noparse]
· I'm not sure what you are trying to do in the "Control" routine ??? Exactly what do you want to happen at what temperatures ???
· You can·use the "temperature" variable, just make sure you do it BEFORE the LCD routine. Because the LCD routine destroys the value in "temperature".
· Also, the value in "temperature" is in 0.1'C units. So 140'C will be the value 1400 (NOT 140). This may be what was causing you grief.
Bean.
·The next time you need a hero don't look up in the sky...Look in the mirror.
Post Edited (Bean (Hitt Consulting)) : 12/24/2008 1:57:44 PM GMT
Please post the BS24p code.
Bean.
